trunklid props #436232
08/12/09 10:03 PM
08/12/09 10:03 PM
orangeville,PA
P
plmczy Offline OP
plmczy  Offline OP
P
orangeville,PA
What do you guy's use to keep your trunk lid open? lookin for something I can scrounge from the pick and pull. later shawn
Re: trunklid props [Re: plmczy] #436233
08/12/09 11:37 PM
08/12/09 11:37 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The little hydralic cylinders they use to hold up the hatch on most new cars works pretty well, and they come in several lengths. The old hood prop rod works too, but sometimes they are a pita on a trunk lid. Gene
Re: trunklid props [Re: poorboy] #436234
08/13/09 10:00 PM
08/13/09 10:00 PM
orangeville,PA
P
plmczy Offline OP
plmczy  Offline OP
P
orangeville,PA
Any idea how long of one to use? The wifes sport-trac uses them to keep the hood open, they are short in size. The sedan trunklid is sorta heavy, so I'm wondering if those would be enough to hold it open? Thanks, later shawn
Re: trunklid props [Re: plmczy] #436235
08/13/09 10:29 PM
08/13/09 10:29 PM
Redwood City Ca.
B1arno Offline
B1arno  Offline
Redwood City Ca.
Pep Boys or any auto parts stores carry these new. They carry many different sizes and are cataloged by application. I would try and determine the lenght needed and pick one from maybe an SUV.
Arno
Re: trunklid props [Re: B1arno] #436236
08/13/09 11:46 PM
08/13/09 11:46 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We had a mid 80s Lebaron hatchback, I can tell you without a doubt that hatch weighs a lot more then any 30s or 40s trunk lid, even the huge business coupe lids.
That said, you probably will want a longer one, its a long reach from closed to open, you will have more mounting options with a longer cylinder. Mounting locations are going to be the trick to having a smooth opperation, and I suspect you will have to do some trial and error to get it right. The factory used a prop rod type thing. The long arm mounted between the trunk frame and the lid and it expanded until a little lever locked it open, you lifted past the lock point then lowered the lid a few inches to set on the lock. To close the lid, you lifted past the lock point, and the lock released so you could lower the lid. Often you had to lift past the lock point a couple times before it would lock or unlock so you could hold it open or close it. Pretty neat little deal, but could get frustrating. Hard to find ones that still work, so that must have been an issue through the years. Gene
Re: trunklid props [Re: poorboy] #436237
08/14/09 11:08 AM
08/14/09 11:08 AM
orangeville,PA
P
plmczy Offline OP
plmczy  Offline OP
P
orangeville,PA
Thanks guy's. I wasn't sure if they had any kind of prop from the factory. When I got my car it didn't have a trunklid with it. I didn't see any signs of a prop with it. Thanks again for the ideas. later shawn
Re: trunklid props [Re: plmczy] #436238
08/14/09 02:19 PM
08/14/09 02:19 PM
East TN.
Moparsky Offline
Moparsky  Offline
East TN.
The auto parts store cylinders would most likely be your cheaper choice.
For shinner choices try a street rod vendor for deck lid props, like:
http://watsons-streetworks.com/hood_deck.html
http://www.yogisinc.com/results.cfm/-/Category=2356/search_cd=prop/results.cfm
John
Re: trunklid props [Re: Moparsky] #436239
08/15/09 01:08 AM
08/15/09 01:08 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If I still had my 39, I'd take a picture of the factory unit, but the car is long gone. Gene
