8 3/4 pinion seal
#435832
08/12/09 05:13 PM
08/12/09 05:13 PM
Posts: 76 Pittsburgh, PA
roadrunnerh
Pittsburgh, PA
Hello everyone - I hope someone can help. Last year I replaced the pinion seal on my 1968 Road Runner 8 3/4 "742" case. After receiving a new seal and then comparing it to an NOS seal, I went with NOS since it was obviously more beefy and the newer one appeared cheap and thin (both the rubber and the metal). Here I am a year or so later, and the seal is leaking again. Not sure if it was faulty or whether I didn't tork the pinion nut tight enough. I used a tork wrench and it did not leak until now.... Anyone have any good tips? I plan on installing another NOS seal this weekend. Oh, I do not have a lift. I jacked up the car and used jack stands - which also makes tightening/loosening with a breaker bar a biotch - not much leverage. ![](/ubbthreads/images/graemlins/frown.gif)
Harry 1968 Road Runner 1975 Scamp
Re: 8 3/4 pinion seal
[Re: roadrunnerh]
#435833
08/12/09 06:01 PM
08/12/09 06:01 PM
Posts: 26,008 Rio Linda, CA
John_Kunkel
Rio Linda, CA
How old are the NOS seals? Rubber does have a shelf life.
[Re: John_Kunkel]
#435834
08/12/09 06:37 PM
08/12/09 06:37 PM
roadrunnerh
Pittsburgh, PA
Not sure on the actual age of the seal, but the rubber portion is plyable and doesn't appear brittle. The new seal I purchased last year (and returned) just seemed like junk.
[Re: MoparforLife]
#435836
08/12/09 07:41 PM
08/12/09 07:41 PM
roadrunnerh
Pittsburgh, PA
No, I didn't check, but to give some history, I purchased this 742 chunk from Mancini's back in 1997. It was rebuilt with new gears, etc. I put MAYBE 1500 miles on this care since I replaced the center section.
[Re: 70SWGR]
#435839
08/13/09 08:26 AM
08/13/09 08:26 AM
Posts: 75,098 A Banana Republic near you.
JohnRR
I would check that yoke to see if it has a groove. Did you get the front of the housing clean and use silicone?
You need to look at the yoke for a groove where the seal rides , and does it have a DUST SHEILD?? There was a REASON the factory installed dust shields on yokes and for some reason the aftermarket deemed them NOT NECESSARY . Also are you sure it's leaking from the SEAL and not getting past the splines and leaking from under the yoke nut/washer?
I agree on the NOS seal thing , rubber does not last forever and I'm pretty sure the original seals on 742's were LEATHER , contact Dr. Diff he has a GOOD 742 seal available .
[Re: roadrunnerh]
#435841
08/13/09 09:58 AM
08/13/09 09:58 AM
Posts: 15,487 Florida
scratchnfotraction
Doctor Diff is the 8 3/4 guru here on the board Quality Body Shop Drivetrain 110 Division Street, Polson,MT 59860 406-883-4772 doctordiff@gmail.comgood guy to talk with,good service also ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: scratchnfotraction]
#435844
08/13/09 04:04 PM
08/13/09 04:04 PM
roadrunnerh
Pittsburgh, PA
No, problem. I just called Randy's ring and pinion and talked to a guy there about ordering a seal (I have yet another NOS one). He told me they sell the National Oil Seal brand, and when I asked, he informed me that they are "made overseas" UGH! Anyone here recommend a brand of seal to use?
[Re: roadrunnerh]
#435845
08/13/09 04:48 PM
08/13/09 04:48 PM
scratchnfotraction
the ones that are made of leather allways leak dont know why the 742 seal cast 2x as much as the other seals ![](/ubbthreads/images/graemlins/shruggy.gif) neoprine seal from napa will work,light duty IIRC but seals better than the leather type good luck with the leak ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70SWGR]
#435846
08/13/09 06:45 PM
08/13/09 06:45 PM
roadrunnerh
Pittsburgh, PA
I cleaned the front of the housing and mating surface. I didn't think I needed to use silicone. I followed the '68 factory service manual.
[Re: DoctorDiff]
#435848
09/08/09 05:04 PM
09/08/09 05:04 PM
roadrunnerh
Pittsburgh, PA
UPDATE...Well a friend with a lift and a compressor helped me out today. I purchased the correct pinion seal from Dr. Diff. last month. Once we pulled the yoke we discovered a deep wear ring around it! This unit was "rebuilt" by Wade at Mancini's back in the mid 90's. It has only 1,200 miles MAX on it. I find it very difficult to believe they used a new yoke when it was rebuilt. Anyhow, We were able to remove the yoke from the 742 case 3:23's I had in my garage, and the yoke which had approx. 90,000 miles on it looked really nice. So...it was really the yoke which was causing the leak rather than the seal - we did replace the seal anyway.
