Undersized Timing Chains? #435218
08/11/09 08:47 PM
08/11/09 08:47 PM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
What is the purpose of these-told that if you use after market caps and line bore and hone you have to use them! But line boring just brings things back to zero-right! Am I missing something here.
Re: Undersized Timing Chains? [Re: JohnnyBeGood] #435219
08/11/09 09:50 PM
08/11/09 09:50 PM
md
mopars4ever Offline
mopars4ever  Offline
md
The block gets bored along with the caps. So the crank will be closer to the cam after it gets bored.
Re: Undersized Timing Chains? [Re: mopars4ever] #435220
08/11/09 10:04 PM
08/11/09 10:04 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Technically, if the machine shop does its job competently and compensating-thickness main journal bearings are manufactured/available, an undersized timing chain should not be required.
That said, sometimes an undersized timing chain is the appropriate "fix."
Check out this link and scroll down to the "Line Boring / Honing" section:
http://www.speedomotive.com/t-about.aspx
Re: Undersized Timing Chains? [Re: D_C] #435221
08/12/09 12:08 AM
08/12/09 12:08 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a new set of caps installed on a 440 block and the regular Rollmaster chain would BARELY go on it was so tight!
I want my fair share
