Re: Tap size?????
[Re: 70dusterjohn]
#435021
08/11/09 08:34 PM
08/11/09 08:34 PM
Posts: 19,355 north of coder
moparx
1/4 x 24 tap drill is : #4 1/4 x 27 tap drill is : #3 1/4 x 32 tap drill is : 7/32
Re: Tap size?????
[Re: BILLYJAY]
#435022
08/11/09 08:39 PM
08/11/09 08:39 PM
Posts: 16,923 NC
440Jim
NC
Trust me on this one, I do this all the time. 1/4-32 National extra fine series. (or Unified Thread Standard) Drill 7/32" (0.2188") then tap. --------------------------------- 1/4-28 National fine series. Drill #3 (0.2130") then tap. ---------------------------------- 1/4-20 National coarse series. Drill #7 (0.2010") then tap. (13/64 is acceptable, but a slightly looser fit. not class 2). http://www.physics.ncsu.edu/pearl/Tap_Drill_Chart.html
Re: Tap size?????
[Re: 70dusterjohn]
#435029
08/12/09 10:22 AM
08/12/09 10:22 AM
Posts: 16,923 NC
440Jim
NC
Okay, so I found the tap all is good.. But I pull the fitting out of the head and there is no way that I can tap it without first drilling it out.. Is that normal.. and if so what size drill do I need to use... This is for the oil lines in the Indy heads.. To put the holley jet in it.. Thanks guys..
Sounds like you have not tapped metal before. Here is a tip, after drilling, chamfer (bevel) the entry. Start the tap straight into the hole (check carefully). When tapping, start by turning the tap 3-5 turns to get it started. Then back out 1 turn to break the chips. Then reverse every 1 turn or if the tap feels hard to turn. This avoids breaking taps, which is really easy with #6, #8. A looser drilled hole is less likely to break a tap, but makes threads with less strength.
3 common types of taps: 1) tapered - long lead (taper) for easier turning, but doesn't reach the bottom of the hole 2) bottoming - very little lead, harder to turn more difficult to start straight, but gets close to the bottom of the hole 3) plug - good compromise of above
Re: Tap size?????
[Re: BILLYJAY]
#435031
08/13/09 07:52 AM
08/13/09 07:52 AM
Posts: 4,206 New York
polyspheric
New York
Glad you found it - BTW: 1/4-24 is very common on all 1976 and older Harley motors, so any dealer will have some hardware (but only a few have the tap or die).
Boffin Emeritus
