5.7L Hemi conversion does it matter what ECU? #434909
08/11/09 04:10 PM
08/11/09 04:10 PM
Thayer, MO
bohmer2 Offline OP
bohmer2  Offline OP
Thayer, MO
I have a 5.7 that I am putting in a 39 plymouth. I would like to run factory stock parts to stay on the cheap side if possible.
AS I understand the 2003 ECU's did not control the transmission so I was thinking this may be a good option if I go with a 5 Speed tranny. But if I run a 518 auto I will need something to control the kickdown so I would want the Tranny control, which means either a separate TCU or can I use a later ECU and control the 518 tranny?
Re: 5.7L Hemi conversion does it matter what ECU? [Re: bohmer2] #434910
08/11/09 04:44 PM
08/11/09 04:44 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
a 518's kick down is cable operated.... the later RE trans are computer controlled
Re: 5.7L Hemi conversion does it matter what ECU? [Re: BlakDak] #434911
08/11/09 04:56 PM
08/11/09 04:56 PM
Thayer, MO
bohmer2 Offline OP
bohmer2  Offline OP
Thayer, MO
So with the kickdown on the 518 cable operated can it be used with the drive by wire system on a new hemi?
Re: 5.7L Hemi conversion does it matter what ECU? [Re: bohmer2] #434912
08/11/09 05:23 PM
08/11/09 05:23 PM
BlakDak Offline
BlakDak  Offline
I think the rams had some sort of set up for it.... I am avoiding the whole drive by wire thing, so I don't know much about it.
I'm either going to use a generic AEM ecu or a GM ECU for the LSx engine.
also the trans isn't an issue for me as I will be using a t56.
the trans adapter thing is mentioned here...when I have more time I can get the direct link
http://www.hotrodlane.cc/
