What is the "general Automotive Grease" in FSM? #434845
08/11/09 02:32 PM
08/11/09 02:32 PM
Berwyn, IL
challenger70 Offline OP
Berwyn, IL
In reading through the FSM on rebuilding my 4 speed they refer to a general automotive grease or something similar I forgot exactly, what kind of grease is it? They refer to use it to hold roller bearings in place during assembly, etc.
Re: What is the "general Automotive Grease" in FSM? [Re: challenger70] #434846
08/11/09 02:48 PM
08/11/09 02:48 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Regular gun grease. Or use vaseline.
Re: What is the "general Automotive Grease" in FSM? [Re: MoparforLife] #434847
08/11/09 03:25 PM
08/11/09 03:25 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Just chassis grease, like you'd use for a ball joint.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: What is the "general Automotive Grease" in FSM? [Re: DynoDave] #434848
08/11/09 03:35 PM
08/11/09 03:35 PM
Berwyn, IL
Berwyn, IL
cool thanks guys. Since I actually do not have any and was looking into getting some and a gun what is a good brand?
Re: What is the "general Automotive Grease" in FSM? [Re: challenger70] #434849
08/11/09 03:43 PM
08/11/09 03:43 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
For wheel bearings I only use the mopar grease. The rest of the time I just use Valvoline, which can be had at pretty much any parts store.
Re: What is the "general Automotive Grease" in FSM? [Re: Neil] #434850
08/11/09 04:03 PM
08/11/09 04:03 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
When used to just hold needle bearings in place, the main thing is that it is compatible with the lube. Otherwise, I'd suggest bacon grease for that great aroma when powershifting!
Re: What is the "general Automotive Grease" in FSM? [Re: RodStRace] #434851
08/11/09 06:44 PM
08/11/09 06:44 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: What is the "general Automotive Grease" in FSM? [Re: RodStRace] #434852
08/11/09 08:49 PM
08/11/09 08:49 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
You've been sniffing the grape scented diff. lube again, haven't you...
DynoDave
Member # 12304
Re: What is the "general Automotive Grease" in FSM? [Re: DynoDave] #434853
08/11/09 10:29 PM
08/11/09 10:29 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Anything is better than the smell of old diff lube with additive in it!
