Re: Powerglide in small block E body? [Re: SB449VALIANT] #434789
08/12/09 12:53 PM
08/12/09 12:53 PM
IN
Irun5snd8th Offline OP
IN
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434790
08/12/09 03:08 PM
08/12/09 03:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Nothing wrong with using stock glide cases, even stock 1.76 gear sets. You wont have any strength issue's.
A few parts in those tranny's are need to be replaced, but after this you will have a strong transmission.
I have personally put pass after pass on a stock glide with stock 1.76 gears. Built by yours truely, turning 1.07 60ft times
A few things that need changed.
-300M input shaft
-aftermarket clutch hubs that holds more clutches
-billet servo piston-Kevlar bands
-1.76 planets
-aftermarket valve body
-deep pan
-pump mods
-case mods
If your not chasing E/T in a class, lots of people don't care to give up a little E/T for consistency.
E/T loss could be substantial, maybe a tenth or more. Then again it might not be near that much with the right converter.
I want to add that converter choice is a little more crucial in a glide, so ask around and get some recommendations.
Re: Powerglide in small block E body? [Re: Bob_Coomer] #434791
08/12/09 03:26 PM
08/12/09 03:26 PM
IN
IN
If I do this my converter will be an ATI and I will be sending an ATI core to them and tell them my specs to have one built.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434792
08/12/09 03:43 PM
08/12/09 03:43 PM
EVANSVILLE,IN. & MCCORDSVILLE,...
RACEEWING Offline
RACEEWING  Offline
Did you know that Jerry Meny runs a pg? He had some issues with starter rings comming apart, almost sawed the frame into.
Re: Powerglide in small block E body? [Re: RACEEWING] #434793
08/12/09 03:52 PM
08/12/09 03:52 PM
IN
IN
Do you know what kit or adapter that Jerry was using?
One thing that I am taking into consideration is using the Coan adapter kit and using an actual Powerglide without a Bell. This for the simple fact that there are always spare glides laying around in my buddies shops and trailers for that matter.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434794
08/12/09 04:53 PM
08/12/09 04:53 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
JW bell here, in a big block A body though. Stock case with Bruno's shield on the trans, fits tighter spots than most shields, and bolts to the pan not a sheet metal strap under the pan. I cut the glide bell housing off in my garage with a sawsall and a die grinder. No issues here with the JW bell. There are a lot of choices for a glide. Stay away from helical aftermarket gear sets, the stock 1.76 is the budget way to go, if you ever upgrade don't consider anything but a straight cut set.
Re: Powerglide in small block E body? [Re: Dan Brewer] #434795
08/12/09 05:59 PM
08/12/09 05:59 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I don't think that the ultra bell is any larger than the 727 bell and we know that it will fit. If I were buying new I would consider the ATI case/bell. I do run JW bells, but had problems with their "wheel". This was with 850Hp though. Run a Reactor alum wheel now.
I will be running a JW Glide with "The Wheel " what kind of problems will I be encountering ?
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Powerglide in small block E body? [Re: chryco] #434796
08/12/09 08:28 PM
08/12/09 08:28 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I don't think you will have any problems. I first adapted my PG with a TCI adapter plate. Used it for years but when I took it apart the flexplate was broken between each mounting bolt. It came apart when I took it off. I then bought a bell and cut the PG bellhousing off and bought a wheel. Worked excellent, no problem that I can recall. My next step was to go with a complete JW cased trans. Bought it with a wheel and a SFI deep pan. No blanket or flexshield required. I subquently bought one of the JW rollerized tailhousings. Again, I've had no problem, had to space out the starter but JW provides shims for that. All this went into a 68 Barracuda, I wouldn't go any other way. However if starting over at this time I would look at some of the other SFI cases out there.
Re: Powerglide in small block E body? [Re: chryco] #434797
08/12/09 11:11 PM
08/12/09 11:11 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
I had one loose a section of ring gear and broke the ultra bell, ripped through the headers and poked a hole in the oil pan. Diaper on the engine saved the car. I took it out and it was cracked at every weld.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Powerglide in small block E body? [Re: Dan Brewer] #434798
08/13/09 02:24 PM
08/13/09 02:24 PM
IN
IN
Any more info? This has been a great thread for learning.
Re: Powerglide in small block E body? [Re: Irun5snd8th] #434799
08/13/09 05:28 PM
08/13/09 05:28 PM
RACEEWING Offline
RACEEWING  Offline
Jerry phone # 812-319-6878
Re: Powerglide in small block E body? [Re: RACEEWING] #434800
08/13/09 06:01 PM
08/13/09 06:01 PM
IN
IN
Thanks.
