What color Loc-Tite for convertor bolts.? #434644
08/11/09 11:17 AM
08/11/09 11:17 AM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
What color loc tite do you guys recomend for the convertor bolts ?
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434645
08/11/09 11:20 AM
08/11/09 11:20 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
RED.......
Re: What color Loc-Tite for convertor bolts.? [Re: Thumperdart] #434646
08/11/09 11:21 AM
08/11/09 11:21 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Re: What color Loc-Tite for convertor bolts.? [Re: 70dusterjohn] #434647
08/11/09 11:24 AM
08/11/09 11:24 AM
KENTUCKY
KENTUCKY
Thanks .........
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434648
08/11/09 11:31 AM
08/11/09 11:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yup red you may have to heat slightly with a propane torch to remove but after years of loose converter bolts i find that no problem.
Re: What color Loc-Tite for convertor bolts.? [Re: Dodgem] #434649
08/11/09 11:33 AM
08/11/09 11:33 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
I use the stuff in the blue container. I don't have to heat it up to remove.
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434650
08/11/09 11:35 AM
08/11/09 11:35 AM
Az
Crizila Offline
Crizila  Offline
Az
BLUE!!! Plenty tight with blue. You use red and you will have '0' fun taking it back appart.
Fastest 300
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434651
08/11/09 11:36 AM
08/11/09 11:36 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
There are a cupple of red loc-tites #271 is what I would use
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: What color Loc-Tite for convertor bolts.? [Re: Crizila] #434652
08/11/09 11:37 AM
08/11/09 11:37 AM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
You can tell us guys that take ours apart more often
Re: What color Loc-Tite for convertor bolts.? [Re: Irun5snd8th] #434653
08/11/09 11:50 AM
08/11/09 11:50 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I use red and have no problem getting the bolts out I have never even used heat
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What color Loc-Tite for convertor bolts.? [Re: Irun5snd8th] #434654
08/11/09 11:51 AM
08/11/09 11:51 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Or perhaps the guys that realise how effective blue Loctite is... Most auto manufacturers have used blue to retain the caliper mounting bolts since the 70's if they figure it's good enough for everyone's brakes with the liabilities involved then it's probably more than adequate for torque converter bolts...
Re: What color Loc-Tite for convertor bolts.? [Re: 1_WILD_RT] #434655
08/11/09 12:13 PM
08/11/09 12:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
271 (red) Make sure to remove all traces of grease and oil or your wasting your time.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What color Loc-Tite for convertor bolts.? [Re: pittsburghracer] #434656
08/11/09 12:56 PM
08/11/09 12:56 PM
Blue, if you want to be able to remove it without a hassle, especailly if there the small bolts like the stock ones
Post deleted by Defbob [Re: pittsburghracer] #434657
08/11/09 02:49 PM
08/11/09 02:49 PM
Re: What color Loc-Tite for convertor bolts.? #434658
08/11/09 06:00 PM
08/11/09 06:00 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Red on a 6 bolt crank flexplate and 5/16 vert bolts, blue on an 8 bolt and the 7/16 bolts.
WIZE
In Car:
Re: What color Loc-Tite for convertor bolts.? [Re: Streetwize] #434659
08/11/09 06:42 PM
08/11/09 06:42 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I allways figure if it needs loctite, it may as well be real loctite, never really had to heat anything to get apart, just allways careful to not round off the head. Red for me, I use blue for aluninum.
Re: What color Loc-Tite for convertor bolts.? [Re: Thumperdart] #434660
08/11/09 06:51 PM
08/11/09 06:51 PM
KENTUCKY
KENTUCKY
I found this on the Loctite website,,,,
RED
OEM specified as 271
High temperature, high strength for heavy duty applications
Designed for larger fasteners 3/8" to 1" (9.5mm to 25mm)
Locks studs, bushings and large fasteners against vibration loosening
Strengthens slip and light press fits
Removable with heat and hand tools
BLUE
Locks threaded fasteners against vibration loosening
Ideal for nut and bolt applications 1/4" to 3/4" (6mm to 20mm)
Prevents threads from rusting and leaking
Removable with hand tools for easy disassembly
Temperature range: -65 degrees to 300 degrees Fahrenheit (-54 degrees to 149 degrees Celsius
Re: What color Loc-Tite for convertor bolts.? [Re: 69CHARGERMD] #434661
08/11/09 08:58 PM
08/11/09 08:58 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Blue is a good for most any thing,,271 red is if it absolutly, posativly, has to keep from coming apart, either will work but 271 is stronger.
Re: What color Loc-Tite for convertor bolts.? [Re: dartman366] #434662
08/11/09 09:33 PM
08/11/09 09:33 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
RED !!
Re: What color Loc-Tite for convertor bolts.? [Re: VernMotor] #434663
08/11/09 10:05 PM
08/11/09 10:05 PM
illinois,u.s.
beezer Offline
beezer  Offline
illinois,u.s.
If you absolutely, positively dont ever want it to come apart, there is a green loctite that will not let it come apart without a maximum amount of effort.
