Re: t/a resto ?'s
[Re: cataclysm80]
#434082
08/11/09 11:00 AM
08/11/09 11:00 AM
Posts: 1,527 minnesota
Kirby
minnesota
I doubt that you'll be able to find a parts car with a good trunk floor to cut patches out of.
AMD makes the best reproduction trunk floor.
I'd suggest thoroughly stripping your original floor & trunk extensions of all paint & seam sealer for a good look. Take pics first so that you can reapply the seam sealer correctly later.
If you end up needing the whole trunk floor then install the AMD trunk floor.
If you think most of the original metal is good and you only have a couple soft spots, then cut patches out of the AMD trunk floor to replace your soft spots. Carefully cut out your soft spots back to good metal and trim the patches to fit perfectly, and Butt weld them into place using a piece of copper to back up the weld while welding. (weld doesn't stick to copper) If you do it right, no one will know it's been patched.
Tav
I don't think you can put in a one piece trunk pan without pulling a quarter can you? Patching would be ideal if you have good metal to weld to-
Re: t/a resto ?'s
[Re: 70killerbee]
#434084
08/11/09 11:52 AM
08/11/09 11:52 AM
Posts: 1,101 Ont, Canada
moparo
Ont, Canada
Pull the tail panel out and slide it in from the back of the car
performancecarrestorations.com
Re: t/a resto ?'s
[Re: kingkt]
#434085
08/11/09 11:54 AM
08/11/09 11:54 AM
Posts: 4,051 Connecticut
jeff968
Connecticut
I had the same issue with my interior floors on my T/A project and decided to patch them as 90% of them were clean. Cool project you have. I'm a 30 year T/A owner and restorer so let me know if you have any questions. I know you've already contacted Barry in AK who runs the registry. I'll be registering my T/A at DMV this week after 6 years of restoration!!! This is what I started with: http://www.challengertaregistry.com/photos/tas_in_barns/via_internet_burnt_ta.jpg
1970 Dodge Challenger T/A
Re: t/a resto ?'s
[Re: jeff968]
#434088
08/11/09 12:39 PM
08/11/09 12:39 PM
Posts: 11,022 Farmington, CT
KISSAlien
Farmington, CT
So are you bringing it to the show Sunday?
Re: t/a resto ?'s
[Re: 70killerbee]
#434089
08/11/09 01:44 PM
08/11/09 01:44 PM
Posts: 4,165 Florida
cataclysm80
I've heard you can get it in through the trunk opening if you cut off only the front left corner (near the fuel sender wire) and rotate it into place.
Do you guys thing it would go in if you took out the rear seat bracing? That would be easier and less visible than a tail panel.
Tav
Re: t/a resto ?'s
[Re: cataclysm80]
#434091
08/11/09 01:50 PM
08/11/09 01:50 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Tav
No it wont go in taking out the seat bracing because of the wheel wells.
Looks like that TA was striped and left to rust. doesnt look like it caught fire. What a shame.
