Post deleted by Defbob
[Re: RussW]
#431019
08/07/09 11:25 PM
08/07/09 11:25 PM
Re: Powermaster 140amp Alt Puked
[Re: RussW]
#431020
08/07/09 11:42 PM
08/07/09 11:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Last time out in June no issues , I pull the car out today to check things over for a bracket event tommorow and not charging. I take alt down to the shop , the diode trio is puked, they fix me up and I'm out the door in about 30 min they said it'll go again . I'm only zingin this about 6200 through the lights and I'm using a small March drive pulley. I thought stepping up to the P Master would end this but I guess not. Any ideas or should I carry a spare.
And what was their reason that it will fail again, sure isnt the revs
#431022
08/07/09 11:43 PM
08/07/09 11:43 PM
Posts: 989 Rather be in Fallon, Nevada
RussW
super gas
super gas
What gauge size is your output wire, what type of alternator is it , and where is your battery located?
I believe it's 10 ga. wire to alt, GM 1 wire alt and 2 Optimas in trunk
[Re: MR_P_BODY]
#431023
08/07/09 11:46 PM
08/07/09 11:46 PM
RussW
super gas
super gas
Something about the frame of the alt wasn't right for the output. I'm electric Dumb sorry
[Re: RussW]
#431024
08/07/09 11:53 PM
08/07/09 11:53 PM
MR_P_BODY
Alt's produce AC power... the diode bridge is there to convert the AC into DC power(3 + diodes and 3 - diodes)
