Re: Tell me about installing & using wide-band O2 sensor!
[Re: racerx]
#429832
08/08/09 11:33 AM
08/08/09 11:33 AM
Posts: 15,478 the boonies
aarcuda
the boonies
I quite like the look of this: http://www.gtechpro.com/egs.html
Its $300 for the tach and another $230 for the wide band add on?
i was going to get one of those but i ended up getting the LM1
I also Like that setup and posted up that system awhile back with very little response.
same here. apparently, no one uses it and i didnt want to be the guinea pig
as for the LM2, the forum there has lots of unhappy people usingit. theres lots of bugs with it (or there was).. thats why i went with the LM1 (ebay) and im very happy with it
check out the attachment. its a jpg i made from the log file and added some data point
[Re: PolyDart]
#429833
08/08/09 11:38 AM
08/08/09 11:38 AM
aarcuda
the boonies
i just looked at the INOVATIVE web site and they dont list the LM-1 in their product page,is it still available or is the lm -2 a replacemet?
LM-2 is the replacement. You needed a serial port for the LM 1 to work. The LM 2 connects via USB.
you can get a serial to USB cable from radio shack that can hook your lm1 to a usb port. im using one right now
[Re: aarcuda]
#429834
08/09/09 06:31 AM
08/09/09 06:31 AM
Posts: 2,915 A shed in England
Tig
A shed in England
I'll be the guinea pig in a month or two
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#429835
08/09/09 04:47 PM
08/09/09 04:47 PM
Posts: 4,068 Mo.
racerx
Mo.
Tig Please post up results...Thax
[Re: Mr71Bee]
#429838
08/09/09 11:05 PM
08/09/09 11:05 PM
BradH
Do these sensors work if I run leaded race gas?
Dallas
From what I've read, lead trashes the sensor. Somebody please correct me if I'm wrong on this point.
And thanks to everyone who has posted on this. I'm considering a system seriously, but haven't made any decisions on brand, single vs. dual sensors, etc.
[Re: BradH]
#429839
08/09/09 11:18 PM
08/09/09 11:18 PM
Posts: 6,295 U.S.
moparniac
U.S.
Go single and save money and just put another bung on the other side to check that bank whenever.....
Mopar Performance
[Re: CJK440]
#429841
08/10/09 10:12 AM
08/10/09 10:12 AM
quick77rt
Parts Problem
Parts Problem
I run my auto meter directly in my x pipe, might not be the perfect spot but it works. Is as basic as most say...weld in the bung tilt it up a bit, if all is cold let the unit preheat until you fire it. This is a simple vid, not worried about ide ect...just wot but with a six pack and spray its needed. Im surprised for the minor cost 3-4 hundred more people dont have them... Dont be afraid of the wide band units. http://www.youtube.com/watch?v=1JjBce4OyxoWOT wideband test.. http://www.youtube.com/watch?v=_Za7lfxoDFc
[Re: aarcuda]
#429843
08/10/09 12:51 PM
08/10/09 12:51 PM
BradH
Such as? Is this stuff that was supposed to have been fixed in their 7/09 upgrade, or other issues that are still out there?
[Re: jinxy]
#429846
08/10/09 03:54 PM
08/10/09 03:54 PM
quick77rt
Parts Problem
Parts Problem
Most the ones ive seen all have in the instructions where they would prefer to see them placed, then you got to sort it out. I was runing one in each side but its overkill for me. You could alway but a bung in each side and swap from time to time, if all is equal????? My X pipe is very near my headers so all worked ok. Im no expert, this is just how I did mine, and it works pretty good. Quote:
I just ordered the Innovate DB gauge kit($229.00)Summit. My car has tti headers on a small block with full 2 1/2" exhaust. Where is the best place to install the single sensor?
Good info on this thread
Jeff
[Re: BradH]
#429848
08/10/09 08:24 PM
08/10/09 08:24 PM
aarcuda
the boonies
cant say for sure. i looked on there back in april when i was looking looking to buy and i saw all the problems and went with the lm1. i had borrowed one from a friend and it worked so i went with a known unit vs an unknown with lots of bad press.
if they fixed the problems, that would be great. maybe an update is in the future.
[Re: aarcuda]
#429849
08/12/09 01:42 PM
08/12/09 01:42 PM
Tig
A shed in England
I've spoke to a few race guys who run the FAST and Innovate stand alone systems. They run leaded race fuel but change the sensor every season, a couple are blow thru turbo VW guys. The only real difference, I'm told, is the response of the sensor. The units calibrate themselves every time they are switched on as far as I'm aware. Another tip they told me was to mount the sensor at least 12 inches from an open header end as the turbulance can give false readings. I'll post results as soon as, but I'll have to fab fancy header extensions as the ends are close to the 'box crossmember / mount. I'm also ordering an extra sensor mount and 2 bungs. Thanx
