440 Balancer bolt Question #429806
08/06/09 10:27 AM
08/06/09 10:27 AM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I am assembling my 440 and I have a question about which balancer bolt to use.
It is a 1976 cast crank 440.
One bolt is approximately 1.25 inches long
The other is approximately 2.00 inches long
Both measurements are taken with the washer off.
One could be a SB bolt. I don't want to bottom out the big one and think things are tight etc.
Any help here?
Thank you for your support.
ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: 440 Balancer bolt Question [Re: toyotajeep] #429807
08/06/09 11:38 AM
08/06/09 11:38 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
1.25"
The 2" may be nice to start pulling it on though then switch to the 1.25???
Re: 440 Balancer bolt Question [Re: toyotajeep] #429808
08/06/09 12:34 PM
08/06/09 12:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Either will work as long as they don't bottom.
Re: 440 Balancer bolt Question [Re: 62maxwgn] #429809
08/06/09 01:14 PM
08/06/09 01:14 PM
scratchnfotraction Offline
measure how deep the hole in the shaft is..
then cgeck it against the bolts..
