70 Charger Disks - Convert to one piece rotors?
#427622
08/03/09 07:23 PM
08/03/09 07:23 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
I have some 70 Charger OEM disk brakes - the ones with the 2 piece rotors. Some questions: First, will one piece rotors fit on - if not directly, is there a different bearing that is needed? Second, these had the Kelsey Hayes calipers - what options are there to replace them with newer calipers? Will calipers and caliper adaptors from a later car bolt up and work?
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
Re: 70 Charger Disks - Convert to one piece rotors?
[Re: G_T]
#427623
08/03/09 08:12 PM
08/03/09 08:12 PM
Posts: 4,740 Florida
BDW
[Re: BDW]
#427624
08/03/09 11:48 PM
08/03/09 11:48 PM
G_T
Texas, Dallas
Thanks - that's a good article on the whole swap process but doesn't address my question.
Can the two piece rotors be replaced with uni-cast rotors? Any difference in the bearings?
2012 Charger SRT8
[Re: G_T]
#427625
08/04/09 12:59 AM
08/04/09 12:59 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Yes there is a differance, the inner bearing is larger, there is no suitable bearing to adapter the unicast rotor to the early spindle.... Which is why Dr Diff sells an adapter to allow the larger bearing to be used with the early spndle... Second part of your question asked about Kelsey Hayes calipers.. If you have single piston calipers like a 70 should then you have Bendix calipers... If you have four piston calipers you have 66-69 vintage brakes on your 70... But assuming you have Bendix calipers you can further upgrade your brakes by swapping the current caliper adapters for a pair off a car equipt with 11.75 brakes & pin style calipers... The last pair I got camr off a 76 Cordoba... That allows you to install the larger 11.75 rotor... If you have the 4 piston brakes you'll need to replace the spindles...
[Re: 1_WILD_RT]
#427626
08/04/09 06:43 AM
08/04/09 06:43 AM
BDW
[Re: BDW]
#427627
08/04/09 02:26 PM
08/04/09 02:26 PM
G_T
Texas, Dallas
Awesome & Perfect !
Thanks guys!
2012 Charger SRT8
