Re: 3SPD BELLHOUSING ?
[Re: ALG]
#427084
08/03/09 08:50 AM
08/03/09 08:50 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
does the 3spd bellhousing have the same bolt pattern as a 4spd and does it use the same diameter bearing retainers as 4spds? i want to change my 3spd to a 4spd but i dont know if the bell is the same or different. Thanks Alan
It depends upon which bellhousing you have. Some later ('70s) BHs are drilled with dual bolt patterns, but most likely you'll need a new BH with the 4-speed pattern. O.D. or non-O.D A-833? Or NP435 granny first gear 4-speed?
What year, make and model is your vehcle? V8 or /6??
[Re: In_The_Pink]
#427085
08/03/09 09:14 AM
08/03/09 09:14 AM
ALG
1968 /6 3SPD TO A A833 4SPD.
[Re: ALG]
#427086
08/03/09 03:05 PM
08/03/09 03:05 PM
In_The_Pink
Milwaukee, WI
There's some good info here: http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Your BH is too old to have the dual pattern, so you'll need a 4-speed pattern BH with the non-O.D. size IBR bore hole.
Definitely sign up over at www.slantsix.org if you haven't already.
