Re: max wedge hood best way to cut 2 holes for carbs ?
[Re: junkyardmaxie]
#426143
08/02/09 11:42 AM
08/02/09 11:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I assume your cutting from the top side/painted side, tape off the area... tape it well back and use a saber saw with a fine tooth blade... take your time and then finish it with a fine file(draw filing)
[Re: hemi-itis]
#426147
08/02/09 01:44 PM
08/02/09 01:44 PM
Posts: 12,593 Great Neck,LI,new york
hemi-itis
Measure twice,,,,,,,,,cut slow
[Re: hemi-itis]
#426148
08/02/09 03:07 PM
08/02/09 03:07 PM
the proper way to do this is put in your carb center studs on both carbs. put some grease on the tip of your studs lower the hood slowly till the hood just touches your carb studs. then remove your hood and go to home depot and buy the 5" or 6" large hole saw for recessed lighting holes, and put pilot hole in the grease mark and drill out, perfect fit.
[Re: junkyardmaxie]
#426150
08/03/09 02:27 PM
08/03/09 02:27 PM
Posts: 89 oregon
ramcharger1964
oregon
Be sure to put some masking tape directly on the ara where the blade is going to contact the metal. Cut from the outside of the hood. This will greatly reduce chipping of the paint. Afetr your done mix a small (tiny) amount of epoxy primer and with a small brush pain the exposed bare metal so rust won't start creaping iun under your nice paint. When I did my 64 hood I used a die grinder with a good cutoff wheel - these are a lot more controllable than a saw blade.
Hell B!tch Racing Co.
