Re: Could a Line Lock kit be used as emergency brake al
[Re: PolyDart]
#425309
08/01/09 11:57 AM
08/01/09 11:57 AM
Line lock solenoids are not rated for continuous duty. Eventually the solenoid could fry and release the brakes.
It not only can, it will. Between a friend I've known since 68 and I, "we" have used up 4 LineLocs over the years. The last unit I put in my old FJ40 Landcruiser was a micro-loc.
However, NONE of these units are meant for anything more than an additional parking device or hill-holder.
[Re: Blakcharger440]
#425313
08/01/09 03:25 PM
08/01/09 03:25 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
I cant get the factory E-brake cables to work with the aftermarket rear disc brake kit that I have.
What is a good alternative that I good use for an E-Brake/Parking Brake?
sounds like you want to use it as a PARKING BRAKE , EMERGENCY brake means something completely different , and no you can not use one as an emergency brake .
[Re: JohnRR]
#425314
08/01/09 05:11 PM
08/01/09 05:11 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Thanks John and yep,I got the two mixed up!
My rear brake kit did not come with E-brake cables and the calipers I am using do not want to work with my factory cables.
I do not want to leave my car parked without a parking brake and have it somehow "slip" out of gear and go rolling off somewhere but I sure would like something to use an emergency brake also.
Anybody have suggestions on what to use?
Re: Could a Line Lock kit be used as emergency brake also?
#425316
08/01/09 06:41 PM
08/01/09 06:41 PM
Posts: 19,972 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
My Cj has a Line Lock hooked up to a dash-mounted toggle switch, and I use it when off-roading to hold the Jeep in place on a hill if I have to start it in an off-camber situation, or if I stall going up/cresting a hill, that kinda thing...but only for 5-10 seconds at a time. Set it, step on the clutch, start the engine, let off the clutch slowly, and as it starts to grab, flip the Line Lock off.
Earning every penny of that moderator paycheck.
DBAP
