.020 off the bottom of the heads. #424561
07/31/09 06:54 AM
07/31/09 06:54 AM
Washougal,Wa
Dodge Offline OP
Dodge  Offline OP
Washougal,Wa
Thinking about picking up some heads from a local Mopar guy. Will I have any problems getting the in take to seal. The heads have been cleaned up on the bottom .020. Thanks Terry
Stand behind your word
Re: .020 off the bottom of the heads. [Re: Dodge] #424562
07/31/09 07:05 AM
07/31/09 07:05 AM
scratchnfotraction Offline
should be fine with the .020 off
Re: .020 off the bottom of the heads. [Re: Dodge] #424563
07/31/09 08:33 AM
07/31/09 08:33 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
.020 is not much more than a good truing trim. should be fine.
Re: .020 off the bottom of the heads. [Re: scratchnfotraction] #424564
07/31/09 08:44 AM
07/31/09 08:44 AM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
Run 'em, every .020 milled =.3 in compression, should be better...
Re: .020 off the bottom of the heads. [Re: MoparforLife] #424565
07/31/09 10:28 AM
07/31/09 10:28 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
The heads will seal, but your intake may not seal without milling the sides and bottem.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: .020 off the bottom of the heads. [Re: Noblewk] #424566
07/31/09 10:58 AM
07/31/09 10:58 AM
Upper Midwest
Upper Midwest
Don't mill the intake. If you mil anything do the intake side of the heads. At .020 it should not be nessessary.
Re: .020 off the bottom of the heads. [Re: MoparforLife] #424567
07/31/09 12:47 PM
07/31/09 12:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Since you will probably be using a Fel pro composition gasket .039 instead of a steel shim .020 it will put them right back where there are stock. Don't worry be happy!
