Is it the Same? #422991
07/29/09 02:40 PM
07/29/09 02:40 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
The kick down (don't care if I'm using the wrong terminology) from a 1972 Charger 400 engine with a 2 barrel carb and 727 transmission as a 71 Cuda 383 727 4bbl?
Grandma always said I had "hands of gold"!
Re: Is it the Same? [Re: CHRGR69] #422992
07/29/09 03:51 PM
07/29/09 03:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
usually different. there ere 4 V and 2 V brackets
Re: Is it the Same? [Re: Dodgem] #422993
07/30/09 12:13 PM
07/30/09 12:13 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
not even close
Re: Is it the Same? [Re: Dodgem] #422994
07/30/09 12:33 PM
07/30/09 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there's 2 and 4bbl RODS , the one from the upper bellcrank to the carb , but brackets ???
also I think the 72 will be a one piece and the 71 a 3 piece ..
just use a lokar
Re: Is it the Same? [Re: JohnRR] #422995
07/30/09 03:39 PM
07/30/09 03:39 PM
scratchnfotraction Offline
Bouchillon
Re: Is it the Same? [Re: JohnRR] #422996
07/31/09 11:10 AM
07/31/09 11:10 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
just use a lokar
I have the Lokar kit. Just eliminating all possible stock options available.
Lokar, kick down, Bouchillon, Mancini
