727 with a throwout bearing and no converter?
#422887
07/29/09 12:38 PM
07/29/09 12:38 PM
Posts: 4,872 connecticut
pnypwr
connecticut
hi all, I dont usually post here but this is something you race folks may be able to help me with: I just bought a 68 roadrunner and it came with a mountain of parts some very odd things and alot of race parts...alot of direct connection stuff and two 727 torque flites. One is the orig to the car the other is a highly moddified trans, the bell has been cut off...luckily it came with a brand new lakewood blow shield...but here is where it gets weird! there is an input shaft and relese bearing like a std trans...and no provision for a torque converter. the front pump has a b&m part number on it cf 101 a! Does anyone know what this is? I had mopar tech guru moper over and hes never seen anything like it, ill attach a pic! Keep in mind this car was getting put together ion the late 70s eraly 80s so who knows...but its got a ton of treasure with it...thanks for any info
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
Re: 727 with a throwout bearing and no converter?
[Re: S/ST 3040]
#422890
07/29/09 12:47 PM
07/29/09 12:47 PM
pnypwr
connecticut
so is it a shiney paper weight? or have any real use in a modern day world
[Re: pnypwr]
#422891
07/29/09 12:51 PM
07/29/09 12:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They were quite pricey in the day but with the high stall converters the clutch-flite went by the way side... some guys would by it for their old school set ups so its not a paper weight.... I bought one of them way back when
[Re: pnypwr]
#422892
07/29/09 01:07 PM
07/29/09 01:07 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
I cant see the back of the trans in the picture, does it have a stock style tailshaft or does it have the B&M short tailshaft? and I agree someone probably would like to have one for nostalgia racecar or display Ron...
[Re: Mopar Ron]
#422893
07/29/09 01:08 PM
07/29/09 01:08 PM
pnypwr
connecticut
thats still wrapped in plastic, ill take a look thks
[Re: pnypwr]
#422894
07/29/09 01:13 PM
07/29/09 01:13 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I thourgh about using one when I put my car together but didn't have the room to put another pedal in the car.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Mopar Ron]
#422895
07/29/09 02:32 PM
07/29/09 02:32 PM
pnypwr
connecticut
looks like a reg long tail shaft...in a b body youd need a carrier brng with a short tail...lol
[Re: pnypwr]
#422896
07/29/09 05:31 PM
07/29/09 05:31 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I did mention the clutchflite.. But I'd never seen one. I thought they would be an iron case, old type trans... this was a normal B torqflite they chopped the bell off. Weird..
[Re: pnypwr]
#422897
07/29/09 05:44 PM
07/29/09 05:44 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
definetely a clutchflite, the problem with them is that most of the early valve bodies were non low band apply. To make them safe you have to spend mega bucks, and they are still questionable at best. I just bought one for 350 and put 2500 in it trying to make it safe. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
