I have used a inner valve spring out of a set of small block dual springs set that worked fine on a 906 without the inner lip machined off, sorry that I can't tell you the part number as that was a lot of years ago. Pull one of your springs off and measure the inner hieght and inner diameter of your current springs and call one of the better cam comapny and ask them for a inner spring that will fit in your heads and add 60 to 75 lbs added pressure at max lift, which will be probally 20 to 30 lbs on the seats
If you have a new set of the Eddy valve springs you can also see what the pressures are on your heads, probally a different installed hieght on the two different heads so you will need a valve spring checker to see. BTW, check the pressures on the old spring while your at it
If you can get 150 to 180 lbs on the seats and 325 to 400 lbs open pressure on your cam now I would do that in a heartbeat
