Page 5 of 9 1 2 3 4 5 6 7 8 9
Re: 360 swap day 3 today. update PICS! [Re: 1_WILD_RT] #421346
08/07/09 01:33 AM
08/07/09 01:33 AM
Santa Rosa, NOR*CAL.
Just Cameron Offline OP
I believe Garret was refering too the fact 360's are externally balanced...
Not mine.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421347
08/07/09 01:38 AM
08/07/09 01:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not mine.
I thought the late model ones are still extrenally balanced just don't require the jumbo weight... Be the first to admit I don't know late model stuff that well but....
Re: 360 swap day 3 today. update PICS! [Re: 1_WILD_RT] #421348
08/07/09 01:41 AM
08/07/09 01:41 AM
Mine was externally balanced when I got it, sure...
It isn't now.
I drilled some huge holes in the crank and JB Welded lead fishing weights in there myself
Don't knock it, this trick always won me the Pinewood Derby!
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421349
08/07/09 01:55 AM
08/07/09 01:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
SaWeeet!!!
Re: 360 swap day 3 today. update PICS! [Re: 1_WILD_RT] #421350
08/07/09 02:06 AM
08/07/09 02:06 AM
Yeah, that's another thing I remembered to do tonight. Before bolting the new flexplate to the crank I matched it to the torque converter boltholes and made a big ol' line with a permanent marker. My first 318 rebuild I had no idea the holes were slightly offset, so I had to have a buddy use a breaker bar on the damper bolt while I played a very slow and frustrating game of "Trial and error" wedged underneath the Duster.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421351
08/07/09 02:16 AM
08/07/09 02:16 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If the torque converter has a drain plug & Mopars generally do.. You'll find there is a small hole (9/32ish) in the flex plate that lines up with the plug but I thinking 180 out.. It's been to long I can't say with certainty... Suffering from Part Timers...
Re: 360 swap day 3 today. update PICS! [Re: 1_WILD_RT] #421352
08/07/09 02:32 AM
08/07/09 02:32 AM
Mine does not have a drain plug, I rotated the 318 crank with a socket and breaker bar looking for it (Out of the car this time. See hoist pics ) as I unbolted the flexplate.
My stocker in the 318/904 did, my MP unit does not.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421353
08/07/09 07:22 AM
08/07/09 07:22 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd like to see pics of your solution for the bypass hose. me, I redrilled my heads to reuse my LA RPM air gap.
BTW, the smaller waterneck is on all '80-up small blocks, and IIRC is the same size as a chevy as well.
2017 Grand Cherokee Overland
Re: 360 swap day 3 today. update PICS! [Re: patrick] #421354
08/07/09 10:36 AM
08/07/09 10:36 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I literally took like some Honda Civic 1" hose and cut it down. It looks crappy, but they don't have any bulk 1" hose where I am.
Re: 360 swap day 3 today. update PICS! [Re: sharpie] #421355
08/07/09 11:18 AM
08/07/09 11:18 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
how'd you handle the 90 degree turn? or does the honda hose have a molded bend in it?
Re: 360 swap day 3 today. update PICS! [Re: 1_WILD_RT] #421356
08/07/09 09:55 PM
08/07/09 09:55 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
With the motor having 517k on it, I take it that the duster has been very reliable
The 360 swap is looking great so far!!
Re: 360 swap day 3 today. update PICS! [Re: patrick] #421357
08/07/09 10:36 PM
08/07/09 10:36 PM
I'd like to know, too.
Currently I have a slightly kinked LA hose on there I'd like to not have to use.
Brian, snag me some detail shots and let me know what year/model part it was.
Re: 360 swap day 3 today. update PICS! [Re: DusterKrazy] #421358
08/07/09 10:40 PM
08/07/09 10:40 PM
Well, I bought it at 238K and rebuilt the 318 at 250,000.
My second year in college, at about 258K I drove it through the Eel river. Made it across, miraculously. Not something I recommend doing or something I would do twice.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421359
08/07/09 10:47 PM
08/07/09 10:47 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Can you insert a spring inside the bypass hose to keep it from collapsing, like the lower radiator hoses have?
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421360
08/07/09 10:52 PM
08/07/09 10:52 PM
Probably not.
I am considering using 2 short pieces of rubber hose and a whole mess of threaded plumbing fittings.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421361
08/07/09 10:58 PM
08/07/09 10:58 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If you have some tubing you could make one of these on a smaller scale and just use rubber at each end.
http://www.hotrodscustomstuff.com/Cars/Road%20Tour%20Car/SR%20Guide/final-05.jpg
They do make 45 degree fittings for the intake, but I'm thinking the odds of getting it clocked in the right spot and tight enough at the same time aren't very good, plus it might look kinda half-arsed.
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421362
08/07/09 11:04 PM
08/07/09 11:04 PM
the other option is to cut 2 holes in the hood and use 12" of universal flex-hose.
Re: 360 swap day 3 today. update PICS! [Re: Just Cameron] #421363
08/07/09 11:05 PM
08/07/09 11:05 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I vote for this solution.
Re: 360 swap day 3 today. update PICS! [Re: OzHemi] #421364
08/07/09 11:14 PM
08/07/09 11:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I'm sure the dimensions in the picture are wrong, but something like this in the intake may work.
Re: 360 swap day 3 today. update PICS! [Re: Neil] #421365
08/07/09 11:19 PM
08/07/09 11:19 PM
Something like that would be perfect if I thought I had the clearance to thread it more than half a turn at best.
