Milodon #31150 oil pan #421036
07/27/09 10:24 PM
07/27/09 10:24 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Hey Guys
I am running the Milodon #31150 oil pan. A buddy just told me that I should not be running a windage tray with that pan because it has one built in and I could be hindering oil draining back to the pan fast enough, is that true
Derrick
Re: Milodon #31150 oil pan [Re: Hyper Henry] #421037
07/27/09 11:21 PM
07/27/09 11:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I doubt a windage tray would hinder drain back much.
all the extra oil you were running likely made the windage tray inoperative! LOL!!!
Re: Milodon #31150 oil pan [Re: Dodgem] #421038
07/28/09 08:23 AM
07/28/09 08:23 AM
ky
68roadrunner Offline
ky
i am putting that pan in my new ride. i talked to milodon they said just run the pan w/built in tray and nothing else.
Re: Milodon #31150 oil pan [Re: Hyper Henry] #421039
07/28/09 08:33 AM
07/28/09 08:33 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I would run it without any other tray.
RIP Monte Smith
