Questions about using Brake Quiet product... #420716
07/27/09 05:39 PM
07/27/09 05:39 PM
SeventySatellite Offline OP
I have some of the CRC Brake Quiet product (that red gel stuff). I know I'm supposed to apply it to the back side of the outer pad where the metals contact each other, but should I apply it to the back side of the inner pad also?
Is this a good product? I saw an aerosol brake quiet product at the auto parts store also, but I bought the gel.
Re: Questions about using Brake Quiet product... [Re: SeventySatellite] #420717
07/27/09 05:48 PM
07/27/09 05:48 PM
hooziewhatsit Offline
I would. I believe all it does it make sure the parts don't rattle/vibrate against each other causing a lot of ruckus.
Re: Questions about using Brake Quiet product... [Re: SeventySatellite] #420718
07/27/09 05:48 PM
07/27/09 05:48 PM
use the gel as the spray coats too wide of surface & is wastefull & it attracts debris. Yes it works well & use it sparingly only on the contact points & yes on the inner pad. the outer pad needs its ears crimped so it is solid whereas the inner pad needs some clearance to float but hit the areas(w gel) where the back of the pads contact anything
Re: Questions about using Brake Quiet product... [Re: RapidRobert] #420719
07/27/09 05:55 PM
07/27/09 05:55 PM
I had a couple of cars that were driving me crazy with squealing/squeaking brakes.
We put the disc brake quiet on the back side of the pads where the caliper/piston touches them and it worked perfectly!
Re: Questions about using Brake Quiet product... [Re: RapidRobert] #420720
07/27/09 06:05 PM
07/27/09 06:05 PM
The reason I ask is because the inner part with the rubber around it is the only area that the back side of the pad would come in contact with.
Re: Questions about using Brake Quiet product... [Re: SeventySatellite] #420721
07/27/09 06:10 PM
07/27/09 06:10 PM
when your buttoned up ready to go the piston will be out past the dust seal making metal to metal contact
Re: Questions about using Brake Quiet product... [Re: RapidRobert] #420722
07/27/09 06:13 PM
07/27/09 06:13 PM
Got it
