Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 1_WILD_RT] #420368
07/29/09 07:57 PM
07/29/09 07:57 PM
BAREFOOT BEACH SOUTHWEST FL
HEMIBULLITT Offline OP
super street
super street
Originally it looked & again someday it will look like this...
BTW I don't know who's car this is, Andy440 had the picture & it's my cars twin...
Thanks Wild R/T, your project will bring you a lot of great times over the next few years!
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: HEMIBULLITT] #420369
07/30/09 12:07 PM
07/30/09 12:07 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
Replacing the tiny, crappy electric pump with the stock mechanical Carter, adding the short steel fuel line from the pump to the vapor separator the previous owner threw out, and new rubber hoses, of course. Go to measure to make sure, and I have a 3/8" sender with 5/16" line from tank to pump. Not a '68, but a September, 1969 built '69 R/T. Why would they use a 3/8" sender and only a 5/16" line the rest of the way? Do I use 3/8" or 5/16" line at the sender to connect the two different size lines? I'll use the $.95/foot stuff and grater clamps to see if everything works before buying the $20/foot KV hoses.
Re: 3/8 FUEL TANK UNIT CORRECT FOR 68 CORONET R/T 440? [Re: 375inStroke] #420370
08/02/09 01:16 AM
08/02/09 01:16 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I put a new tank and 3/8 sender in a 70 Challenger about 10 years ago. I ended up making a ground wire the secured to the frame on one end and I simply wrapped a ton of it around the nipple coming out of the sender. Read dead on full like it should.
I want my fair share
