70 Challenger Throttle Cable??? #420192
07/27/09 10:36 AM
07/27/09 10:36 AM
On the south side of Nowhere
S/ST 3040 Offline OP
We need part number or at least application for an
E-body with a tall intake and single Dominator.
Pictures of set-up appreciated as well.
Thanks.
Re: 70 Challenger Throttle Cable??? [Re: S/ST 3040] #420193
07/27/09 11:07 AM
07/27/09 11:07 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
check in the tech section, it has a list of lenghts and part numbers. I got a cable at autozone or oriellys for 19.99 and I used the AR engineering bracket works very well.
Re: 70 Challenger Throttle Cable??? [Re: Joshs68] #420194
07/27/09 11:38 AM
07/27/09 11:38 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
A slant six throttle cable were long, and should be hard to find.
I bet the slant six is longer than the big block, unless the throw is funky or something.
Re: 70 Challenger Throttle Cable??? [Re: Bob_Coomer] #420195
07/27/09 12:18 PM
07/27/09 12:18 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I ordered mine and they were in the next day for under $20.00 you cant go wrong, much thicker cable than a lokar, and it goes together so easy with AR'a bracket a caveman could do it. fit my M1 4500 flange manifold with a 1050. I swapped to an M1 for a 4150 and a 950 bigs/holley reused everything with a small adjustment.
Re: 70 Challenger Throttle Cable??? [Re: S/ST 3040] #420196
07/27/09 03:30 PM
07/27/09 03:30 PM
AndyF Offline
AndyF  Offline
It kind of depends on the intake manifold. The M1 4500 intake is a lot lower than something like an Indy 440-3X. I have throttle bracket and throttle return kits that will fit any intake that I'm aware of but there isn't a universal kit that fits every single intake.
The slant six cable is the one to buy. If you can't find that one then the one from a pickup truck will usually work but it is about an inch shorter. I published all the cable part numbers years ago.
Re: 70 Challenger Throttle Cable??? [Re: AndyF] #420197
07/27/09 04:19 PM
07/27/09 04:19 PM
This is on a SB with a Super Victor and 1 1/2" Wilson adapter.
We will probably use a baseplate bracket for the cable, just
the existing cable will not physically reach.
I understand the E-body cables are different than A-body,
where they attach or go through the firewall?
Re: 70 Challenger Throttle Cable??? [Re: S/ST 3040] #420198
07/27/09 06:55 PM
07/27/09 06:55 PM
High Ridge MO.
MOPARCHAS Offline
MOPARCHAS  Offline
High Ridge MO.
here is mine
Re: 70 Challenger Throttle Cable??? [Re: MOPARCHAS] #420199
07/27/09 07:25 PM
07/27/09 07:25 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Thanks,everbody. I am going to use my old throttle cable and fabricate a bracket to use it.It was only about a 1/2" shy of working,due to the height with the 4150 to 4500 adapter,and using my Jeg's throttle cable bracket.
After looking it over and thinking about it,it should be a pretty easy piece to fab.
