Home Head Porting TOOLS 101..... #4102
10/09/03 07:33 PM
10/09/03 07:33 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Class is now in session...........
Below is my setup, nothing exotic, any home porter with a couple hundred $ can duplicate to do their own stuff. I used to envision pro head porter's work areas as some big clean modern work station. Uh.... Then I saw some in person and in pics. I have seen Ray Barton's Porting area, Rider Racings Porting Room, and a few others. I feel much better about my setup after seeing theirs LOL. One must realize cylinder head porting is a NASTY and DIRTY job. The grindings and dust gets EVERYWHERE. It's just not possible to maintain a completely sanitary work area, nor is it necessary. I try to stay organized and I wipe the workbench off as often as possible, and that's about it...... Anyhow here are some pics:
Nothing Glamorous..... just a 1/2" thick Plywood workbench, ~5 1/2 fet long and aprox 30" deep. Stuffed into the back corner of my shop. You can see my grinder speed control knob (dimmer switch LOL) Hanging to the right of the pic.
I did'nt clean up for the pics. This is how it looked this AM LOL Aluminum shavings and epoxy dust everywhere from Don's INDY inatke being morphed into a W6 intake.
I have custom made Cylinder heads stands that I clamp down to the bench.... This is an old pic of B3's W5's back when I first did them. The head stands make it nice to adjust teh head to angy angle when porting and hold the head rock steady. Most guys just flop the heads on the bench and go at them, but just as a personal preferrence I like the stands. The head bolts on with 2 bolts, and can be removed in ~45 seconds.
As far as tools..... I use a Makita GEO600 1/4" Electric Die Grinder. ~ $100 from MSC industrial Supply. Alot of other places sell them as well. Lowes etc. should be able to order you one. I put ~600 hours on my last one before the front bearing wore out. The motor and brushes still had lot's of life left. So they will last a while. Unlike Air grinders, no oiling to mess with. I have used air before, and I think I actually prefer electric now. You just get used to it and it get's comfortable. The Makita is VERY light, which is important when holding a Grinder for hours on end. Does'nt really get hot etc. Works great. Alos to use air, you better have a fairly large upright compressor.... obvioulsy not every home garage has a compressor capeable of handling an air die grinder for continuous use.
As far as carbides go, these are my basic ones. I have a bunch more but I rarely use them. Short and a long Sanding Mandrel and you are all set. All my short carbides are double cut for iron use. Although I do use two of them also for Aluminum chamber work sometimes depending on the head.
If I could only afford a couple tools, these would be it. 6" Sanding Mandrel with 1/8" pilot, 3/8" head Aluma Cut Carbide in ~4 1/2" (I cut down a 6") and a short double cut "tree" carbide. These are the 3 tools I use most often. All are from Cylinder Head Abrasives www.ruffstuff.com
As far as sand rolls go, If you are not using Standard Abrasives, you are wasting your time. I have used 3M, Norton etc. It's all junk compared to SA rolls. The rolls Goodson sells ARE Standard Abrasives brand put in a Goodson box. I usually buy mine from CHA by the box of 100. I have 120, 80, and 60 Grit, but for a home porter, just buy a box of 60. You can do everything you need generally with 60. OH and I use 1/2" Diameter, 1 1/2" Long Straight rolls. Tapered rolls etc are more $, And I just prefer straight anyhow.
Also a Dial Caliper and Snap gauges are helpfull. LOL And don't forget teh layout dye and a scribe. I have been using Dykem layout dye, but recently started using Starret brand Blue dye, and I like the applicator and the wear characteristics of the Starret better than the Dykem. Starret is avail from MSC industrial supply. www.mscdirect.com
If you are working with aluminum, a lubricant for your carbides will be necessary to keep them from clogging. I use WD40. Some use ATF? But I think a light penetraing oil is best. For light jobs just buy a spray can and spray your carbide when it starts to get clogged. I buy it by the gallon and dip my carbide in it when necessary. You'll get a feel for when the caridge is beginning to clog.....
My porting gloves..... Are'nt they SEXY? Oh not really? Oh well, I told you this was'nt galamorous..... Index finger hole to be able to "feel" the ports and short turn.....
And Safety Equipment...... This is the 3M filter mask I use.... I don't even remember what they cost, I bought a pack of ten of them a while ago. The 3M is ALOT better mask than your regular old 50 ct. Hardware store dust mask. Gotta have one. ESPECIALLY when sand rolling....... The dust that is kickad up is unreal.
My googles.... No safety glasses for me. I've had alot of suff try to come up around normal glasses, and after my first and hopefully only trip to the ER to have a Cast Iron Shard drilled out of my Eyeball, I now will only use a goggle with a TIGHT rubber seal around the face. I actually got this set at Pep Boys for $15 LOL. I HAD a very expensive set from MSC, but IMO these are alot more comfortable and work better for me. I love them. Took me a while to find a set of gogglss that were comfortable, gave me free range of vision, would'nt fog up, and protected 360*.
And lastly my Husqvarna Chainsaw Ear Protection LOL. Not only keeps all noise out, but also keps all metal shavings off your ears as well. Love 'em.
Those are the basics..... in recap: You only need a couple well thought out Carbides, 60 Grit Sand rolls, A Sand Mandrel, a Good Die Grinder, and safety protection. OH and LIGHT LIGHT LIGHT. I have a 600 W floodlight in the ceiling aimed right at my workbench, also use a 500W halogen and a 100 watt light to shine at the ports I am working on.
Hey if I can achieve results like these:
With the above setup, no reason you can't either with enough practice. (oh the flowbench helps too LOL)
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4103
10/09/03 07:42 PM
10/09/03 07:42 PM
I could live out there !!!!
Wanna practice on my 906's ??
John
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4104
10/09/03 07:54 PM
10/09/03 07:54 PM
Wow! A lot of info in there. Some nice pics also. What advice would you give to a beginner who has never done any porting work. I have a extra set of junk heads to practice on. Do you know of any good books teaching you how to port? My biggest concern is of porting too much and going srait through the metal. Any advice would be great.
TIA
Re: Home Head Porting TOOLS 101..... #4105
10/09/03 08:01 PM
10/09/03 08:01 PM
Very impressive! I've tried porting, too tedious for me. I'm pleased there are those with skill and willingness to do it. A great porter is an artist.
Re: Home Head Porting TOOLS 101..... #4106
10/09/03 08:19 PM
10/09/03 08:19 PM
You have a lot less of a problem with dust if you built a down draft porting table. I've seen the pro ones, and it looks like it works very well.
Re: Home Head Porting TOOLS 101..... #4107
10/09/03 08:27 PM
10/09/03 08:27 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Cool! Thanks! This thread will get a bunch of responses!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Home Head Porting TOOLS 101..... #4108
10/09/03 08:36 PM
10/09/03 08:36 PM
Alberta, Canada
K
ktbundy Offline
super gas
ktbundy  Offline
super gas
K
Alberta, Canada
Very informative Ryan. I would have thought that an electric grinder would experience some heating problems. I've never tried porting but I bet I can still make a bigger mess than what you've got.lol
Tom
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4109
10/09/03 09:27 PM
10/09/03 09:27 PM
Hazlet, NJ
440Satellite Offline
super gas
super gas
Hazlet, NJ
Wow!!!!! Thats an excellent rightup, great info for us beginers wanting to get into porting, this should go into the tech archives!!!!! Thanks alot and you do some nice work.
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4110
10/09/03 09:30 PM
10/09/03 09:30 PM
Table Rock Lake Missouri
furious Offline
furious  Offline
Wow, I am impressed. Could you give me a clue on how to remove the aluminum from my carbides after I already let them get clogged? Thanks
Re: Home Head Porting TOOLS 101..... [Re: furious] #4111
10/09/03 10:11 PM
10/09/03 10:11 PM
State College, PA
RyanJ Offline OP
moparts member
RyanJ  Offline OP
moparts member
State College, PA
Just coat it in WD40, and start grinding again, the aluminum chunks that were clogging it will fly out.......
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4112
10/09/03 10:23 PM
10/09/03 10:23 PM
Awsomeinfo thanks: This would be a candidate for the Archives~
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4113
10/10/03 12:59 AM
10/10/03 12:59 AM
Since this is a Tools 101, how about some learnin'.
I decided to get a carbide bit, and ended up with a double cut egg shape. I thought since it was double cut it would cut faster, but found it to cut well, but not like I thought it should have. So I figure that the single cut is good for taking alot of metal and double is for a smoother finish. Does this sound right?
Re: Home Head Porting TOOLS 101..... #4114
10/10/03 01:32 AM
10/10/03 01:32 AM
Wow nice Ryan!! My Eddy heads are just itching to make the trip to State College.
Re: Home Head Porting TOOLS 101..... #4115
10/10/03 08:19 AM
10/10/03 08:19 AM
Great write up very helpful thank you I know my W9 are in good hands
Re: Home Head Porting TOOLS 101..... #4116
10/10/03 09:38 AM
10/10/03 09:38 AM
Cornfield. IN
Clair Offline
Pot Stirrer #4
Clair  Offline
Pot Stirrer #4
Cornfield. IN
Very nice detail of what you need to port like a pro LOL
Re: Home Head Porting TOOLS 101..... [Re: Clair] #4117
10/10/03 09:40 AM
10/10/03 09:40 AM
IN
Dartman928 Offline
Dartman928  Offline
IN
Great job Ryan and thatks for posting the info
Re: Home Head Porting TOOLS 101..... [Re: Dartman928] #4118
10/10/03 10:12 AM
10/10/03 10:12 AM
Very good info, how about a pic of your flow bench in action.
Re: Home Head Porting TOOLS 101..... #4119
10/10/03 10:35 AM
10/10/03 10:35 AM
Clinton Twp. MI.
ChargerDude70 Offline
super street
super street
Clinton Twp. MI.
Thanx for the post....lost of usefull info Five Stars...
DODGE...Devistation On Driving Grounds Everywhere 69 Dart Swinger 6.1 Hemi 4-Spd 70 Charger R/T B3/B5 6.1 Hemi Auto 76 Coronet 2008 H.D. Street Glide Aniversary Model 821 of 3000 2011 Challenger R/T T.O. 6spd
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4120
10/10/03 11:04 AM
10/10/03 11:04 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Haven't done a set of heads in a while but i did like using the tapered rolls for tall short sides, just put them on backwards and it'll let you reach farther around the corner than a straight roll, works for getting around corners in the intake runners too. Always used ATF for aluminum, never tried WD40, maybe next time.
Re: Home Head Porting TOOLS 101..... [Re: RyanJ] #4121
10/10/03 11:15 AM
10/10/03 11:15 AM
Western MA, +121 posts on old ...
sixpacstac Offline
super gas
sixpacstac  Offline
super gas
I like my Makita over the air also, good piece. Thanks for the info on the goggles, I will check my local Pep Boys. Gotta' protect the "peepers" , they are WAY too valuable!!!
Rod
-'76 Volare, 340, 950 Holley HP, 3500 stall, 8 3/4 w/4.11's, 11.80 E.T., 113 MPH
