Re: timing issue [Re: deaks] #386968
07/28/09 01:12 PM
07/28/09 01:12 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I used to have the dual line external oiling system and because of drain back i would always be priming it, this may have caused the bush to wear.
Ari
Did your erratic timing lose you much power.
Mick
I couldnt get the timming marks rigth and didnt go to the track this way
when the 440 was 9.1 528 cam it didnt matter as much as it was 12.5 and 613/276 cam
didnt want to hurt the moter
but street driving it was a little better then
1.39 9.85 - 137 mph
Re: timing issue [Re: Ari440] #386969
07/28/09 01:15 PM
07/28/09 01:15 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I had the duel line setup too , if you where priming it and the primming tool gouged (sp) the bushing then it would be oblonged and giving you the skattered timming
1.39 9.85 - 137 mph
Re: timing issue [Re: deaks] #386970
07/28/09 01:35 PM
07/28/09 01:35 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
You sure it's not your timing light getting screwed by the MSD multi-sparks Mick.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: timing issue [Re: Mick70RR] #386971
07/28/09 07:24 PM
07/28/09 07:24 PM
robin hood country
deaks Offline OP
deaks  Offline OP
robin hood country
I've got 2 timing lights Mick and it's lost power since i changed the distributor, however, the old one had the hose trick done to it.
I will call you this week and you can tell me about your woes as well.
Ari
You could be right about the gouging, one way or another i'll sort it because i'm on a mission to run 10 seconds.
Who sells the dist collar
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
