overfill a diff #386342
07/25/09 09:14 PM
07/25/09 09:14 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
I overfilled my suregrip (3.23 742)and when I parked it the last couple times some fluid drained out the yoke end .... now after a few runs around town there is nothing leaking.... would this be normal or do I have a bad seal?? what leaked out was no where near the amount I put in so I'm assuming that I should'nt be concerned or do I need to take it apart??
Re: overfill a diff [Re: ngpSatellite] #386343
07/25/09 09:19 PM
07/25/09 09:19 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Oil shouldn't leak out the seal end even if you overfilled it .
Re: overfill a diff [Re: JohnRR] #386344
07/25/09 09:48 PM
07/25/09 09:48 PM
scratchnfotraction Offline
could be low and your thinking its over filled
my 742 leaks at the pinion seal,when its at the full mark,it will drip oil for a few days and stop..(not driving it anywhere)
then its low,I can start driving it and it will leak some as it oils the front pinion,gets even lower
so I keep an eye on it and as long as its driping the rust prevention I know its full at a glance
also if you check it jacked up in the front of car it will read low on the mark and will be over filled when level
you should be able to R&R the seal on the 742 pinion,it is set up with a spacer and shims
seal will cost a few bones for the 742 case,the leather ones are not that great and leak,use the newer neoprine one
DoctorDiff has them in stock
Re: overfill a diff [Re: JohnRR] #386345
07/25/09 10:35 PM
07/25/09 10:35 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
You need to replace the pinion seal first.
Re: overfill a diff [Re: In_The_Pink] #386346
07/27/09 06:56 PM
07/27/09 06:56 PM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
If it is way too f ull it can cause the fluid to push past the seal i've seen this at work on motors and shaft seals way too many times.
