Post deleted by Defbob [Re: dizuster] #386202
07/26/09 10:30 AM
07/26/09 10:30 AM
Re: Any tricks to removing Drag Link OFF front suspension? #386203
07/26/09 10:43 AM
07/26/09 10:43 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Forty yearsall Ive used is a big hammer and hit it at the right spot.If Im replacing parts pickle fork.Ive done thousands.I can even use the P fork and not damage the boots.Rocky
Agreed all you need is a ball peen hammer. Set your purse down, and hit it HARD (on the side of the centerlink right where the tapered hole is).
I don't even own a pickle fork.
There's got to be a limit on hammer blows before I would start worrying about a safety issue. On some cars the pan has to come off so often it should have zippers
Not to mention that the center link(and other nearby parts that suffer the wrath of the errant blow) will start to look beat and nicked up after doing it this way.
MB
