tire size with offset springs E body #385708
07/25/09 09:37 AM
07/25/09 09:37 AM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
If I move the springs in with the offset hanger kit what is the largest tire size(ET street) and what back spacing will fit the stock wheel wells? I am running a 1972 Barracuda and am building a 9 inch and will make it what ever width I need. I do not want to cut the car but do not mind welding in the spring hangers.
Re: tire size with offset springs E body [Re: tigger1] #385709
07/25/09 10:11 AM
07/25/09 10:11 AM
michigan
challenged448 Offline
michigan
Mine are 11.5-28 with a 15 by 8 wheel 5" back space
Re: tire size with offset springs E body [Re: challenged448] #385710
07/25/09 10:25 AM
07/25/09 10:25 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Chris from New Jersey
Re: tire size with offset springs E body [Re: fig426] #385711
07/25/09 10:27 AM
07/25/09 10:27 AM
East Coast, NJ
fig426 Offline
fig426  Offline
East Coast, NJ
Re: tire size with offset springs E body [Re: fig426] #385712
07/25/09 11:19 AM
07/25/09 11:19 AM
virginia
tigger1 Offline OP
tigger1  Offline OP
virginia
Thanks for the replys. I tried searching but guess I need to learn how to narrow down the results some. I entered tire size E Body and got results for everything.
Appreciate the help
Steve
Re: tire size with offset springs E body [Re: tigger1] #385713
07/25/09 12:14 PM
07/25/09 12:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you use my 1" offset kit, a 59 1/2" wide rearend assembly works nicely with a 10" wheel and 5" of backspacing.
If you use my 1 1/2" offset kit with a 59 1/2" rearend, run a 10" wheel with 5 1/2" of backspacing. You could also make a 58 1/2" wide assembly for 10" wheels with 5" of backspacing.
Re: tire size with offset springs E body [Re: tigger1] #385714
07/25/09 02:41 PM
07/25/09 02:41 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Dr. diff 1.5" kit. stock e body width housing
10"rim with 295/65-15 et drag radial 6.25" backspacing.
Re: tire size with offset springs E body [Re: ToddP] #385715
07/25/09 04:00 PM
07/25/09 04:00 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
315/60/15's
custom cut dana 60 with dr diff relo kit and wheelwell lips rolled some... no rub issues whatsoever. 10" rim 5 " backspace
Mopar Performance
Re: tire size with offset springs E body [Re: tigger1] #385716
07/25/09 04:42 PM
07/25/09 04:42 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
When you search....use quotes...like this:
"challenger tires"
and try + between words too...like this:
"chllenger+tires"
Re: tire size with offset springs E body [Re: Quicksilver440] #385717
07/25/09 05:38 PM
07/25/09 05:38 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
on my 'cuda i was alternating between 28x13.5's & 30x12.5's. made zero difference to my et.
Re: tire size with offset springs E body [Re: rebel] #385718
07/25/09 07:12 PM
07/25/09 07:12 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have super stock springs with one leaf removed and the inboard relocation kit on my 71. I have 295/50 BFG radial TA's on 10" rims.
BB, TT5,Procharged 3300lb Street Car 4.79/154
