What's wrong with this time slip? 60 foot?
#385434
07/24/09 10:13 PM
07/24/09 10:13 PM
Posts: 2,103 East Coast, NJ
fig426
East Coast, NJ
I got one run in tonight before we got rained out. It's my best time yet but I think it should go faster. Any suggestions? 3800 pound Challenger, 416 sb six pack, 4 speed, 3:91, 26" MT drag radials, through a stock TA exhaust.
60' 1.871 330' 5.236 1/8 8.046 mph 87.33 1000' 10.461 1/4 12.497 mph 110.69
Chris from New Jersey
Re: What's wrong with this time slip? 60 foot?
[Re: Dodgem]
#385437
07/24/09 10:21 PM
07/24/09 10:21 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
it should be at least 1.65 that would have you nipping on the 11's Your MPH gain from the 1/8 on is ok your 330 is poor so if you were spinning you were probably spinning out past the 60' Seems you making good power and I assume the stock TA exhaust is knocking you down some more.
[Re: RussW]
#385440
07/24/09 10:31 PM
07/24/09 10:31 PM
Dodgem
Ontario, Canada
Yup I used to run 1.60's on just 295/50 15 TA's 10 to 12 lb john force burnout (but staring in the box) little fenesse off the line and made them work. going to be trickier with a row boat!!??????
[Re: fig426]
#385446
07/25/09 07:10 AM
07/25/09 07:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Don't know if it was sprayed. Calvert fronts. Single adjustable rears. No major spin. Clamped front. It's hard to take pics from the driver's seat.
Get some video of the launch... you will learn a ton, most of your problem is in the 60'
[Re: fig426]
#385448
07/25/09 10:48 AM
07/25/09 10:48 AM
Quicktree
suspension work is probably in order. 90/10 cal trac front shocks. mono spring but maybe one lighter than cal tracs. Cal trac bars and rancho adjustable rear shocks. less air and heat the crap out of the hides. i don't car what they say hot and sticky is well?? hot and sticky!!!
If caltracs are the answer, then how did everyone run so fast back in the day before caltracs or mono leafs? And how are cars running so fast today without caltracs on multi leafs? Just food for thought.
thats easy, more power. how do you think the FAST cars run so fast on bias ply street tires? they make it up on the top end.
[Re: fig426]
#385449
07/25/09 11:03 AM
07/25/09 11:03 AM
Posts: 15,489 the boonies
aarcuda
the boonies
Why do you think it should run faster? What is the engine build and what temp was it that run?
the best run I have so far on my 416 was
60' 1.8315 330 5.215 1/8 8.0163 1/8 mph 88.20 1000' 10.2881 1000' mph 99.67
that was on a real chilly day (in the 60's) ive made changes here and there but havet been back to the track for a few weeks
