ELECTRIC Vacuum pumps... Anyone ever try them ???? #384784
07/23/09 11:18 PM
07/23/09 11:18 PM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
I have been looking at all kinds of vacuum kits for my new motor and wondered if anyone has ever tried or used these electric vacuum pumps.???? http://www.jegs.com/i/JEGS/555/52215K/10002/-1
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: BILLYJAY] #384785
07/23/09 11:45 PM
07/23/09 11:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have a GM pump on my car that pulls about 5". IIRC the original application was Camaro/Firebird. It's a bit noisy, sounds like a vacuum cleaner, but works fine. Works off Ign run side with a relay. I don't think I have more than $75 in the whole system including puke tank. I put a fitting in one valve cover to check it with a gauge. Probably weighs about 5 lbs for everything.
Post deleted by Defbob [Re: BILLYJAY] #384786
07/24/09 12:06 AM
07/24/09 12:06 AM
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? #384787
07/24/09 12:09 AM
07/24/09 12:09 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
never seen one work it's worth
waste of money...I would rather run a converted smog pump from that one company
http://www.gzmotorsports.com/
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: Bob_Coomer] #384788
07/24/09 12:18 AM
07/24/09 12:18 AM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Let me ask again, BOB & Hemifred..have you ever used one??? or it that just your opinions ???
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: BILLYJAY] #384789
07/24/09 12:48 AM
07/24/09 12:48 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: BBR] #384790
07/24/09 01:00 AM
07/24/09 01:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well if you want one that works that is electric this is what you need...But be careful good parts dont come cheaply.
Post deleted by Defbob [Re: BILLYJAY] #384791
07/24/09 01:11 AM
07/24/09 01:11 AM
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? #384792
07/24/09 08:44 AM
07/24/09 08:44 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
Lots of guys that run at local tracks around here run these but. Like Fred said there only used to keep moisture out of the oil on alky motors.
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: moparmxz] #384793
07/24/09 08:49 AM
07/24/09 08:49 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
They do work OK if your only using them to pull mositure out of an alky motor after a run.
they don't even work well for that, especially if you run injection. My buddy put one on and took it off the following weekend.
Re: ELECTRIC Vacuum pumps... Anyone ever try them ???? [Re: MegaDart] #384794
07/24/09 09:29 AM
07/24/09 09:29 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
we have been running the same one for maybe a year. it's a gm version, but a ford is the same. it works well, but if you want to pull 8" of vac. it won't do it.
