Re: What RPM do you roller motor guys idle at?
[Re: Bigcube]
#384701
07/24/09 09:25 PM
07/24/09 09:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your carb has the idle circuit set up correctly, the plugs will stay clean no matter what RPM
Yep
[Re: 70HemiGTX]
#384704
07/24/09 11:55 PM
07/24/09 11:55 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
~ 1,800 - 1,900 for me. Any less and it wants to shut off.
Somethings wrong. My tunnel ram setup ran 9's in the 1/4 and would idle at 900-1000 all day.
[Re: Otherlane]
#384707
07/25/09 06:01 AM
07/25/09 06:01 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I just fired the new engine this week (383 + .030, 4.25 stroke, Engle roller - 262 @ .050, 1.6 Harland Sharps, Herbert lifters and Herbert HERS637 springs).
Have idle set at 1200 due to people here and on speedtalk.com recommending higher idle to keep lifters' rollers lubed.
I could probably set the idle down to around 900 or so, but the convertor allows smooth engagement into gear at the present speed, and I don't want to 'learn something the hard (money) way'.
Right now I have to put smaller restricters in the heads, since the HS rockers allow all the oil to FLY out the rocker shafts...
Will be checking rollers periodically for a while to make sure they're hanging in there.
.02 and a bump...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
