Re: What RPM do you roller motor guys idle at?
[Re: Otherlane]
#384683
07/23/09 08:34 PM
07/23/09 08:34 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
281/288 cam, 112 lobe center. I have it idle around 1200, it would idle lower but no need to.
Post deleted by Defbob
[Re: dartman366]
#384685
07/23/09 09:07 PM
07/23/09 09:07 PM
[Re: Bigbeep]
#384687
07/24/09 01:49 AM
07/24/09 01:49 AM
Posts: 43,289 Bend,OR USA
Cab_Burge
I have idled my 518 at or under 900 RPM in gear with the Mopar brand roller lifters for over three years of street and strip racing, after breaking two of them(the wheels ) and calling Engle, (I thought the Mopar brand where being made by Engle) NOT. Mark Engle said to not let any non pressurized roller lifter idle less than 1300 RPM in gear and have it idle closer to 1500 rpm to ensure adequate splash oiling to the needles in the roller wheels It kind of makes sense I wil probally follow those guidelines from now on
[Re: Thumperdart]
#384691
07/24/09 07:01 PM
07/24/09 07:01 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Mine seems happy around 1500-1600 RPM.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#384692
07/24/09 07:07 PM
07/24/09 07:07 PM
1300 rpm's for me in nuetral but the hemi likes 1400, keeps plugs clean and feels crisp when i crack the throttle.
#384693
07/24/09 07:42 PM
07/24/09 07:42 PM
Posts: 5,000 Tampa Florida
dc426
gotta keep'm separated
Tampa Florida
[Re: Lil Demon]
#384695
07/24/09 07:54 PM
07/24/09 07:54 PM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
About 1200 in park, 1100 in gear. 281/283 at .050 roller.
[Re: dc426]
#384696
07/24/09 07:55 PM
07/24/09 07:55 PM
Quicktree
[Re: Bigcube]
#384701
07/24/09 09:25 PM
07/24/09 09:25 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If your carb has the idle circuit set up correctly, the plugs will stay clean no matter what RPM
Yep
[Re: 70HemiGTX]
#384704
07/24/09 11:55 PM
07/24/09 11:55 PM
ProSport
Akron, Ohio
~ 1,800 - 1,900 for me. Any less and it wants to shut off.
Somethings wrong. My tunnel ram setup ran 9's in the 1/4 and would idle at 900-1000 all day.
[Re: Otherlane]
#384707
07/25/09 06:01 AM
07/25/09 06:01 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I just fired the new engine this week (383 + .030, 4.25 stroke, Engle roller - 262 @ .050, 1.6 Harland Sharps, Herbert lifters and Herbert HERS637 springs).
Have idle set at 1200 due to people here and on speedtalk.com recommending higher idle to keep lifters' rollers lubed.
I could probably set the idle down to around 900 or so, but the convertor allows smooth engagement into gear at the present speed, and I don't want to 'learn something the hard (money) way'.
Right now I have to put smaller restricters in the heads, since the HS rockers allow all the oil to FLY out the rocker shafts...
Will be checking rollers periodically for a while to make sure they're hanging in there.
.02 and a bump...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
