Piston to blcok bore clearance #384676
07/23/09 08:01 PM
07/23/09 08:01 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What should the piston to block bore clearance be on a race motor? Pistons are Speed Pro Hypereutectic 4.35
Re: Piston to blcok bore clearance [Re: DusterKid] #384677
07/23/09 10:43 PM
07/23/09 10:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Should say in the instructions .0035 is my guess.
Think they say .0015 minimum but that is too tight for me!!!
Re: Piston to blcok bore clearance [Re: DusterKid] #384678
07/23/09 11:33 PM
07/23/09 11:33 PM
Go with what Speed pro recommends for thoe pistons in your application Speed Pro has spent millions of dollars over the years doing research and development on those pistons I think that all of the OEM gas engines made in the USA have hypereutuctic in them now from the factory exept maybe the hi output turbo and supercharged motors, maybe even them
