Re: What coil springs are you running?
[Re: rebel]
#384399
07/24/09 11:57 PM
07/24/09 11:57 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
looking at your pic it looks like you have more than an inch of squeeze on your springs. on a post on here earlier i think it was chassisman suggested that the springs only be compressed 1". how well are your rear suspension working with your springs compressed that much as you have? surely your extention must be somewhat limited?
Pics can be deceiving, my 12" springs are compressed one inch with shocks fully extended and they look the same way on the car.
[Re: Quicktree]
#384400
07/25/09 08:07 AM
07/25/09 08:07 AM
STRANGE HYPERCOIL 170# spring
170#s, what the heck you holding up a house?
a heavy early b body. i guess a 1.28 60 foot footbraking isnt working too good with a #170 lb spring.
#384401
07/25/09 08:21 AM
07/25/09 08:21 AM
Quicktree
heck no you need more, then you would get into the 1 teens
[Re: WILD BILL]
#384402
07/25/09 08:54 AM
07/25/09 08:54 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
Q A1 single adj shocks and IIRC their 120# springs. 4 link rear and 2820 car weight.
Now I'm really starting to think I want the springs MEGADART has though. Can't qiut place why
Bill, 90% of the cars here will work fine with qa1 stuff. I tested 4 sets of qa1, 1 set of afco and finally the Eibach. Eibach was the best spring by FAR, and were only a few dollars more...
I have Jerry Bickel on my new car and when I can find out what weight they are will replace with Eibach...
[Re: MegaDart]
#384403
07/26/09 03:32 AM
07/26/09 03:32 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
What was better about them? Did you put them on a spring rater them out of the box to check how close they were to advertised. Some brands are more off than others. Some lose there rate faster especially if they are "lightweight" versions with reduced amount of coils.
