Re: everything was going great and then
[Re: moparlulu]
#382821
07/22/09 02:24 AM
07/22/09 02:24 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
Just did that last week to a friends car, drained the oil out, cleaned & MIG welded. No co 2 or anything. turned out great.
Plynouth VIP '67 TT IC EFI
[Re: plumridiculous]
#382825
07/22/09 09:15 AM
07/22/09 09:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I have done it many times on the car, drain it, I grind the area clean, spray with carb/brake cleaner then blow air through the oil filler cap, weld it up.... set up time usually takes longer than the welding (like said above.... ground the pan itself)
#382827
07/22/09 09:48 AM
07/22/09 09:48 AM
MR_P_BODY
The crack is in the bottom rear about 2 inches from the drain plug. Wten running air in the oil fill should the drain plug be out or in?
Thanks George..
I leave the drain plug out during the whole process (allow the air to move better)... doesnt need to be alot of air, just to move the vapors out
[Re: Quicksilver440]
#382829
07/22/09 03:51 PM
07/22/09 03:51 PM
Posts: 5,080 organ
maximum entropy
organ
a friend of mine blowed his face off doing it in place. i wouldn't.
[Re: maximum entropy]
#382830
07/23/09 11:37 AM
07/23/09 11:37 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I welded a pan in place (steel)... once.
I wouldn't do it again. Was more of a PITA than pulling the pan would have been.
And, what about the ash from the fine amount of residual oil that'll be inside the pan?
And, how are you going to clean ALL the oil out of the crack that you're welding?
To say nothing of the previous poster whose friend got hurt.
This ain't to say it can't be done. Obviously, it can. Just that there are some 'opportunities for learning experiences' that could possibly happen.
If it were mine, I'd just use some yamabond/hondabond to stick a patch of beer can over the offending crack until the pan could be removed for a proper repair.
Oh, and the genuine honda or yamaha sealants are GOOD - no worries.
.02
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: thecarfarmer]
#382831
07/23/09 11:50 AM
07/23/09 11:50 AM
MR_P_BODY
.02
-Bill
I've never had any issue welding them on car(done plenty).... oil will burn if there is any in there but it sure wont explode.... gas explodes... stick your nose to the drain hole and smell if there is any gas vapor... if so let it air for a period of time
#382833
07/25/09 07:40 AM
07/25/09 07:40 AM
MR_P_BODY
I just finished welding the crack up with no problems. I went an inch past the crack both ways, used a magnetic ground to the pan as close as possible, air down the oil fill.
Thanks For the help!!
Glad you got it
#382834
07/25/09 02:11 PM
07/25/09 02:11 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I was a little late to chime in here but when I weld cracks of any kind I always drill a hole at the end of each crack. This helps prevent occurrence.
