Re: Raced my 572 finally the 1st time and won
[Re: camastomcat]
#382188
07/23/09 08:26 AM
07/23/09 08:26 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Hi Guys, need some help. I have been running Mopars for 25 yrs,but this is my first engine with aluminum heads, block, rods and I am not sure if I have a problem or not. What oil pressure does your engines have cold then hot? My dragster sit a little over 4 yrs till last year. I had a battle with cancer and was down for a while. The Auto Meter sports comp gauge was also about 8-10 yrs old so it may have been wrong. But the engine had a 100 lbs of oil pressure cold and you could raise the idle just a hair and it would go up to 120 lbs. when hot was 80 lbs and would go to 100 lbs. when you hit the throttle. I was told that was to much. Well a week are so ago the oil pressure went down to 60-80 cold and 30 hot did not rev it at 30 lbs. to see if would go up. Put a new Auto Meter Pro-Comp on yesterday still has the same oil pressure @ 170 @ idle about 28 lbs. again shut it off with out rapping the throttle to see if it would go up. Is this normal or do I have a problem? THANKS
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: sc301v]
#382190
07/23/09 10:25 AM
07/23/09 10:25 AM
MRMOPAR622
Sweet Home Alabama
THANKS!!!! sc301v, I have a system 1 oil filter when you clean the filter you can see some shiney aluminum and bronze particles in the oil not a whole lot,I would like to see none. The engine is still fairly new and it has had some the 4-5 times I have changed the oil. This time it had a little more bronze than before,so I may take a look at the bronze gear on the dist. just to be safe. It is nice to have some other Mopar people to run ideas by. Thanks Guys
[Re: sc301v]
#382192
07/23/09 10:54 AM
07/23/09 10:54 AM
Posts: 481 Cheswick, PA
Bob_Spelic
Cheswick, PA
1995 S&W hard tail here. Car weighs 1880 with me in it. Engine is race gas 493, 280@.050 roller cam, Indy EZ-1 heads (330 CFM), 13.5 compression (ross 14cc domed pistons), single dominator on an Indy -2 mainifold. Rear end is a Ford 9" with 4.30's and a 33.5x17 tire. Transmission is a JW 1.76 geared glide, converter is an 8" JW stalling at about 5400. 1/4 mile times are in the 8.30's with trap speeds of 159 to 160 @ 7500 RPM. 60 times are 1.18. 1/8th mile is 5.30's at about 129. All times are at about 2800 to 3000 ft DA We mopar dragster guys need to share some information. Not many of us around. My car seems a little slow to me. Do you think I need more stall? I was expecting to be closer to 8.0 than 8.3. Bob Spelic
[Re: Bob_Spelic]
#382193
07/23/09 11:11 AM
07/23/09 11:11 AM
Posts: 6,314 The Swamp
MegaDart
The Swamp
first thing I would do is take the wing off. that could be .1 right there. what is your launch, shift and trap rpm?
edit, I see trap rpm of 7500, sounds like too much for that mild a combo??
[Re: MegaDart]
#382194
07/23/09 11:34 AM
07/23/09 11:34 AM
MRMOPAR622
Sweet Home Alabama
MegaDart, mine has a wing also,maybe not as tall as his. Mine is about 5' or a little more from the ground to the top. My dragster has a 218" W.B. and will run in the low 140's in the 1/8 mile all of our tracks run only 1/8 mile for the weekly Bracket Races. I have only made a few runs with the big engine at this MPH. With the 451 engine it run in the mid to high 120's. It has always handled good,well after I put about 35 lbs in the nose with the big engine. But I would like to pick up a tenth by taking the wing off mine also. Do you think it would be safe to do on my dragster with the short 218"WB? THANKS
[Re: camastomcat]
#382197
07/23/09 04:11 PM
07/23/09 04:11 PM
MRMOPAR622
Sweet Home Alabama
I pulled the bronze gear out,the teeth look fine. But under(bottom) the bronze gear is nice a shiney and has a good bit of wear,also where it sets in the bushing in the block the shaft also has some wearlooks like it has been sanded with sandpaper (very small ridges or grooves)if you could hold it straight. Looks like it may have had to much pressure or downforce on it,and it looks like the bushing has tighten up on the shaft. Going back to see if I can figure out what has gone wrong.
Thanks for the info. camastomcat thats makes me feel a lot better.
