what pushrods with hyd camshaft with adj rockers #381566
07/20/09 09:17 PM
07/20/09 09:17 PM
New Hampshire
n_bogie1984 Offline OP
New Hampshire
seeing i cant get the cam i need in time i am going to throw my hughes 1.6 on my mp .484 hyd camshaft. what pushrods do i need? i tried a standard pushrod and it seemed way to long, to the point the angle was so far off closed it hit the rocker. the block is decked .015, and the eddy rpm heads have been decked .050 with a .040 compressed gasket.
Re: what pushrods with hyd camshaft with adj rockers [Re: n_bogie1984] #381567
07/20/09 09:26 PM
07/20/09 09:26 PM
OH
junkyardmaxie Offline
OH
hi, i have 16 like new crane chrome moly push rods for your application $60.00 shipped bought them from mancini # 69691-16 thanks moparraceman@aol.com
Re: what pushrods with hyd camshaft with adj rockers [Re: junkyardmaxie] #381568
07/20/09 09:41 PM
07/20/09 09:41 PM
New Hampshire
New Hampshire
7.330 thats awful short i think? now that is with useing the hyd lifters and adj rockers?
Re: what pushrods with hyd camshaft with adj rockers [Re: n_bogie1984] #381569
07/20/09 10:03 PM
07/20/09 10:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
What engine is this? If this is a B engine about 8.25 +/-should about do it. The will have to be at least a .125 shorter than the mechanical pushrod which is 8.41 due to the depth of the cup in a solid compared to the h3ight of the plunger in a hydraulic.
Re: what pushrods with hyd camshaft with adj rockers [Re: n_bogie1984] #381570
07/20/09 10:05 PM
07/20/09 10:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your better off measuring it to see what you need instead
of guessing
Re: what pushrods with hyd camshaft with adj rockers [Re: MR_P_BODY] #381571
07/20/09 10:12 PM
07/20/09 10:12 PM
New Hampshire
New Hampshire
well running behind as always i got my first show this weekend. i would think it would be a common length pushrod, and this is on a rb 440
Re: what pushrods with hyd camshaft with adj rockers [Re: n_bogie1984] #381572
07/20/09 10:19 PM
07/20/09 10:19 PM
Upper Midwest
Upper Midwest
Standard mechanical is 9.20 so you will need at least .125 shorter and possibly even a 9 inch will be right for you. Be best to measure for sure. Guessing gets a person into trouble in a deal like this.
