Re: A few more parts for the Demon / R5 P7
[Re: BobsProFab]
#381518
07/20/09 09:00 PM
07/20/09 09:00 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
my custom 6 qt. tank from petersons
[Re: BobsProFab]
#381520
07/20/09 09:06 PM
07/20/09 09:06 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
[Re: LA360]
#381527
07/21/09 08:05 AM
07/21/09 08:05 AM
BobsProFab
sycamore,ohio
i bought a 6 stage barnes pump the segmented pans are supposed to be worth some HP thanks guys
[Re: quick77rt ]
#381531
07/21/09 10:37 AM
07/21/09 10:37 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That is one nice pan, please explain the segmented part (term)...ive seen alot of or R5 pans that were open throught the whole pan bottom, mine is sectioned off, but I dont think its what your refering to as segmented????
Ive also the barns unit.....
Are most running a front drive dist??? vs the rear mount????
The segmented is the vertical walls at each main web, for every segmented area you either allow the oil to travel between them or have a suction line in each segment, helps on windage
[Re: BobsProFab]
#381534
07/21/09 04:47 PM
07/21/09 04:47 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
i have a 4 pickup stainless segmented pan also from moroso that i would sell cheap
i did the front belt drive dist to keep any harmonics from the ign. with a crank trigger, should be a good setup for the RPM's i plan on spinning it
i plan on putting it on the dyno very soon to play with it to see what it likes Bob
Its gonna be fast, mighty fast
