Re: 11x3 drums with fins?? What cars or trucks??
[Re: Dallasdan]
#380453
07/20/09 03:45 PM
07/20/09 03:45 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
11" X 3" drums were used on both the front and rear depending on year/model.
[Re: John_Kunkel]
#380454
07/20/09 05:22 PM
07/20/09 05:22 PM
Posts: 2,256 IL
furious70
IL
my 70 sport fury (originally 383 2bbl power drums) had them on the front. Converted to 73 discs now
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 360view]
#380458
07/22/09 03:30 PM
07/22/09 03:30 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Don't confuse different properties of materials which may or may not be advantageous in certain situations.
Aluminum has a high strength-to weight ratio, so is good for applications that need strength at a minimum weight penalty (aircraft fuselage, wings, etc.)
Aluminum has good heat TRANSFER properties, which make it good for automotive radiators.
Aluminum has nearly double (at approx. 900 Joules/Kg-deg K) the heat CAPACITY of iron (at 473 Joules/KG-deg K) by weight. But, at a little over half the density of iron, makes it slightly poorer as a store of heat than aluminum. By VOLUME, aluminum has a heat capacity of 2.43 Joules/cubic cm-deg K, versus 2.48 Joules/cubic cm-deg K, giving iron the slight advantage in heat storage per cubic centimeter.
In a brake application, heat builds up rapidly and dissipates slowly, therefore heat capacity is a more important property than heat transfer. That's why aircraft brakes are made from steel, stainless steel, carbon, and probably other materials also, but not aluminum.
[Re: MoparMarq]
#380459
07/22/09 03:35 PM
07/22/09 03:35 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
my 70 Charger R/T with a 440 had 11x3 Drum brakes and a luggage rack
why? I dunno....first thing I took off the car....the brakes...not the rack,,,
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#380460
07/22/09 10:59 PM
07/22/09 10:59 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
I bought a complete set of 11x3 drums. I thought about putting them on my Duster. I was told it would be a bad thing to do with that small of a car. But maybe if I did Viper rotors on the front?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
