Re: 70 E body AC clip by fender tag / body ground strap?
[Re: FJ5_Fish]
#379846
07/20/09 06:14 PM
07/20/09 06:14 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
I have a one owner Chall with A/C - I think mine may have a hex head screw by the tag but I am going from memory - I do remember the clip because that routing makes it hard to read the tag. I'll check the location/fastener.
Nope - My memory sucks - Phillips screw.
[Re: FJ5_Fish]
#379847
07/20/09 07:15 PM
07/20/09 07:15 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
Like in the pictures I posted above. That's original.
I have seen other originals like that. Fat headed phillips pan head.
[Re: FJ5_Fish]
#379851
08/21/09 06:35 PM
08/21/09 06:35 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
#10x 1/2" pan head clear zinc phillips screw
[Re: cataclysm80]
#379853
08/22/09 01:44 PM
08/22/09 01:44 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Hey Snoopy, any idea what year / SPD that car in your picture is? Are the early cars different? Where do they ground?
Thanks! Tav
I don't know the SPD, but I have a picture of an Oct 69 Cuda with the weld-in nut.
Re: Early 70 E body has different body/Light ground strap?
[Re: cataclysm80]
#379859
08/23/09 03:09 AM
08/23/09 03:09 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
So your left to decide if you make a square hole & duplicate what every other 70 ebody had or..... Is the radiator yoke original with the body vin? Gotta wonder if that panel got swapped.. I know 73-74 ebodies had differences in the inner fenders, don't know about that panel... It's good your tracking this all down now, it would be a bummer to have to go back later... I trial fit everything multiple times so I won't have problems.. Lots of guys don't & later wish they had...
[Re: gtx6970]
#379863
08/23/09 11:39 AM
08/23/09 11:39 AM
Posts: 4,848 Memphis
HemiRick
Memphis
On my 4 70's 3 have the square nut and 1 doesn't. The one w/o has VIN ending in 09553 and was built in 9-69 I not sure what the SPD is....I do have the fender tag...Its the car with a roof in my sig.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: cataclysm80]
#379865
08/23/09 11:57 AM
08/23/09 11:57 AM
HemiRick
Memphis
bolt and a nut thru a round hole.
[Re: HemiRick]
#379869
08/23/09 01:41 PM
08/23/09 01:41 PM
Posts: 4,165 Florida
cataclysm80
[Re: cataclysm80]
#379870
08/23/09 05:34 PM
08/23/09 05:34 PM
HemiRick
Memphis
Just a note to add to the confusion, my convert is an even earlir car SPD 823 VIN 1074xx and it HAS the square nut for the ground....What I'm thinking is that if guy on the core support making line left off the square nut that they just used the next avail hole....
[Re: 6bblgt]
#379874
08/23/09 11:48 PM
08/23/09 11:48 PM
cataclysm80
Thanks Dan, That's pretty cool! I was hoping you'd chime in. I just went out and checked all over inside and out where the picture shows,... no extra hole. Oh well. I don't see a headlight ground on that pilot car. Got any other pics/info that might have some early build ground wire examples? Tav
[Re: HemiRick]
#379875
08/24/09 02:01 PM
08/24/09 02:01 PM
cataclysm80
Are both cars built at the Hamtramck Michigan Plant?
J?2??0B VIN B is the letter for Hamtramck.
J?2??0E VIN E is the letter for the LA plant.
My car is a Hamtramck car built on assembly line 2. (EN2 on fender tag)
Tav
