SLANT 6- 318 MOTOR MOUNTS #378798
07/18/09 11:47 AM
07/18/09 11:47 AM
NY
MoparGary7272 Offline OP
NY
I heard that by using 80's style small block Ram motor mounts and turning one of them backwards, you can put them on the slant six K-frame and put a small block in there!! Its going into a 73 Dart Sport, what mounts do i use?!?!?! is there other style mounts i can buy?!
It's just to put a running motor in the car to get it driveable to transport back home, and theres a 71 police 318 readily available!!!
Re: SLANT 6- 318 MOTOR MOUNTS [Re: MoparGary7272] #378799
07/18/09 11:59 AM
07/18/09 11:59 AM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
The truck mounts will work on 67-72's, on the 73 you have to swap the K frame or get conversion mounts from schumacher since it's a spool mount car.
