Torsion bar lengths #377994
07/17/09 08:47 AM
07/17/09 08:47 AM
Chesterfield, MIch
Cuda67 Offline OP
super street
Cuda67  Offline OP
super street
Chesterfield, MIch
Thanks for any help. What is the length of the torsion bars in a 65 coronet, and a 66 coronet. Mancini shows from 66 and up b-bodies. I have a 65 coronet with a 70's e-body K-member and the bars are around .880 and I would like to put the .920's or 960's bars in. Any suggestions? The car has a Hemi with aluminum heads and intake.
Thanks again.
Re: Torsion bar lengths [Re: Cuda67] #377995
07/17/09 11:44 AM
07/17/09 11:44 AM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
Thanks again.
41"
Is this a street car? If so, I would suggest a spring rate of at least 200 lbs/inch, which is about a 1.02" diameter bar. That will put your car on the same footing as most new GTs.
