Re: Rocker shaft shimmimg
[Re: CrAzYMoPaRGuY]
#376785
07/16/09 11:42 AM
07/16/09 11:42 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Do your math and you will see that you gained .010 didn't loose it. Using a shim will actually make things worse. You milled .030 and used a .040 gasket. Therefore you increased the distance not decreased. By milling .030 and using a .040 you actually lost ground. Put it together and forget the shims they will make things worse.
I'm hoping I'm OK with the .010 difference...
I'm doing the math trust me!
I cut the head .030 = .030" LESS distance I increased the head gasket from .020"ish to .040"ish = .020 MORE distance
.030 less distance from the cut and .020" more distance from the DIFFERENCE in head gasket thickness makes a total of .010" LESS DISTANCE. Not more. My heads are .010" closer to the cam centerline than before.
I think you forgot to factor in the original .020"ish steel shim factory head gasket in your equation.... that was REPLACED by a .040" Felpro...
Ether way,your good to go without shims. BTW, why would you want to cut the heads .030 and then add .020 back with a thicker head gasket???
I wanted to run the FelPro composite gaskets and increase my compression as opposed to REDUCE the compression. I also didn't want to affect my intake mating, and I've done the .030" cut with Felpro gaskets many times before....
I coulda just cut the heads .020", but I would STILL be checking my lifter preload, the heads have been redone by others and I'm not sure I trust the work!
It's a 9:1 engine, I can't afford to drop compression!
Even compensating for the .020 gasket difference (which I admit miscalculated) a .010 gain isn't a noticable cut no matter how you look at it. It is really no more than a truing trim. You won't even notice a difference. Many thousands of .010 or even up to .040 gains in cutting have been made with no problems or shimming.
[Re: JohnRR]
#376787
07/16/09 04:56 PM
07/16/09 04:56 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
Then you have not been paying attention , shims are for correcting VALVE TO ROCKER GEOMETRY , NOT making up for head/block machining .
LOL
Then why are you running a thicker composite gasket ??? the .010 more you gained might have raised your compression what .1 ???
I prefer the Felpro composiute gasket to a steel shim gasket, and my heads had a terrible surface on them to boot. Looks like somebody sanded them with a rock before the engine was last put together....
Now... Can we get back on topic, it's ROCKER SHIMS I want to know about, not different ideas, different theories, how I can use shims for this, not for that...
ROCKER SHIMS.
Is there a difference between types, vendors,... or?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#376788
07/16/09 05:04 PM
07/16/09 05:04 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
LOL
ROCKER SHIMS.
nce again , get your pencil ready ...
Something must be being lost in the translation from English to Canadian ????
If it ain't broke don't break it ...
[Re: JohnRR]
#376789
07/16/09 05:50 PM
07/16/09 05:50 PM
CrAzYMoPaRGuY
Canada
LOL
ROCKER SHIMS.
NEXT!!!!!
Can it get any more painful?
Either reply about certain types of shims or continue and
AHHH, the beauty of MoParts.....
CrAzYMoPaRGuY
[Re: buildanother]
#376802
07/17/09 09:43 AM
07/17/09 09:43 AM
JohnRR
U.S.S.A.
Wow. all this back and forth, are you understanding that shimming the shaft up will be changing the rocker tip to valve stem geometry like mentioned?
He OBVIOUSLY does not CARE that he's fixing ... fixing ??? ... his NON ISSUE incorrectly.
