2 speed to 3 speed wiper motor swap #376693
07/15/09 10:14 PM
07/15/09 10:14 PM
wi
crscuda Offline OP
crscuda  Offline OP
wi
If you change from a 2 speed wiper to a 3 what all needs to change? Wiper motor, wiper trans, and switch, can you use the same dash wiring?
Re: 2 speed to 3 speed wiper motor swap [Re: crscuda] #376694
07/15/09 10:44 PM
07/15/09 10:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What model?
Re: 2 speed to 3 speed wiper motor swap [Re: NITROUSN] #376695
07/16/09 06:30 AM
07/16/09 06:30 AM
wi
crscuda Offline OP
crscuda  Offline OP
wi
"71" Challenger
Re: 2 speed to 3 speed wiper motor swap [Re: crscuda] #376696
07/16/09 07:21 AM
07/16/09 07:21 AM
N
NITROUSN Offline
NITROUSN  Offline
N
"71" Challenger
Sorry cant help you on the E-body. On the 68-70 b-body the wiring was the same. All that was needed is a motor, crank arm, and switch. No experience with the E-body so I cant give you a positive answer.
Re: 2 speed to 3 speed wiper motor swap [Re: NITROUSN] #376697
07/16/09 03:31 PM
07/16/09 03:31 PM
wi
crscuda Offline OP
crscuda  Offline OP
wi
Thanks NITROUSN, Anybody??
Re: 2 speed to 3 speed wiper motor swap [Re: crscuda] #376698
07/16/09 07:35 PM
07/16/09 07:35 PM
Kentucky, USA
derekeh Offline
derekeh  Offline
Kentucky, USA
Motor, switch, and all of the linkage inside the firewall.... as far as I know anyways. Ive used both 2 speed and 3 speed with the same electricals and had no troubles. Just getting all the linkage can suck :/
Re: 2 speed to 3 speed wiper motor swap [Re: derekeh] #376699
07/16/09 07:46 PM
07/16/09 07:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Optional:
Electric windshield washer pump and bottle.
Re: 2 speed to 3 speed wiper motor swap [Re: Snoopy] #376700
07/16/09 11:36 PM
07/16/09 11:36 PM
wi
crscuda Offline OP
crscuda  Offline OP
wi
Thanks guys, I'm gona give it a try.
Re: 2 speed to 3 speed wiper motor swap [Re: crscuda] #376701
07/17/09 08:33 AM
07/17/09 08:33 AM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Make sure the motor are linkage are matched 70-71 or 72-74
NS1AAR
Re: 2 speed to 3 speed wiper motor swap [Re: ns1aar] #376702
07/17/09 08:54 AM
07/17/09 08:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's the difference in the cam arm ??
