indy headed 408 plugs & timing #376538
07/15/09 08:40 PM
07/15/09 08:40 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
what have you guys found to be the best plug heat range and timing on the indy headed 408's? currently using ar3934 with 10.75 comp and reading the plug it looks like it wants more timing. the heads are the 360-1's.
Re: indy headed 408 plugs & timing [Re: mopar dave] #376539
07/17/09 08:37 AM
07/17/09 08:37 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
hi dave ,guy over here made 640 with the -1 408 and 36 was best on dyno and ngk -7 .i run the -7 and trying 40 deg timming ,potting - 10 and 150 gas on sunday see how it goes.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: indy headed 408 plugs & timing [Re: Ian] #376540
07/17/09 02:19 PM
07/17/09 02:19 PM
Mt Morris Michigan
Mt Morris Michigan
thanks Ian, but what do you meen by potting 10 and 150?
Re: indy headed 408 plugs & timing [Re: mopar dave] #376541
07/17/09 02:28 PM
07/17/09 02:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Dave , wheres the timing @ now?
Re: indy headed 408 plugs & timing [Re: emarine01] #376542
07/17/09 04:52 PM
07/17/09 04:52 PM
Mt Morris Michigan
Mt Morris Michigan
timing is at 35*, but the ground strap on the plug shows color difference nere the tip only.
Re: indy headed 408 plugs & timing [Re: mopar dave] #376543
07/17/09 08:07 PM
07/17/09 08:07 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Give it what it needs, bump it up a couple at a time
Re: indy headed 408 plugs & timing [Re: mopar dave] #376544
07/18/09 04:14 AM
07/18/09 04:14 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
sorry mate ngk race plug -10 heat range and 150 nitrous
Re: indy headed 408 plugs & timing [Re: Ian] #376545
07/18/09 01:19 PM
07/18/09 01:19 PM
Mt Morris Michigan
Mt Morris Michigan
thanks Ian. i advanced the timing to 37* from the previous 35*. my advance is locked out and i notice when i rev the engine with a light on it, the timing will drop back 1*. so, i have 37* at idle and 36* at 3000 and up. anyone ever notice this with lockedout timing?
Re: indy headed 408 plugs & timing [Re: mopar dave] #376546
07/18/09 02:01 PM
07/18/09 02:01 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mine moves a little, its the play in the slot between the dist and drive gear
Re: indy headed 408 plugs & timing [Re: emarine01] #376547
07/18/09 02:21 PM
07/18/09 02:21 PM
Mt Morris Michigan
Mt Morris Michigan
ok, but how many degrees does your fall back? when i had a msd digital6 it would fall back 2*. this only happens when timing is locked out. i'm now using a summit box which i believe is made by mallory. i like it way better.
Re: indy headed 408 plugs & timing [Re: mopar dave] #376548
07/18/09 02:46 PM
07/18/09 02:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I run a 6al with locked 34* @ 1200 idle, mine moves 1 or 2 degrees to 2k then seems to smooth out at high rpm
