Re: 71 340 cast iron intake mods?
[Re: ademon]
#376037
07/15/09 11:58 AM
07/15/09 11:58 AM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
I can let you know what I did. PM me with your phone # and I'll try to catch up with you in the next day or so.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: Rapid340]
#376038
07/15/09 01:55 PM
07/15/09 01:55 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
All I did with mine was gasket match the ports and blend into the runner, then I cut the divider down so only about .200" was remaining.
I also cut away the heat crossover underneath to save weight and installed a tin heat shield on the bottom to keep hot oil from splashing on the underside.
This was a 72 intake but you get the picture.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
