360 LA-Magnum Head hy-brid oil pressure problem #375929
07/15/09 10:23 AM
07/15/09 10:23 AM
Lexington Indiana
mjhallas Offline OP
mjhallas  Offline OP
Lexington Indiana
Anybody running one of these LA block-Magnum head
combos? I bought one in a 78 Power Wagon and the oil pressure runs around 80 psi cold and @ 45-50 psi hot @ 2000 rpm. At idle it drops to 10-20 psi. Its not making any noise or rattling at idle. It dose have the correct AMC lifters and correct hollow push rods. ( checked these during an intake gasket change)I changed the oil and filter to a quality 10w40 without any difference. Should I get concerned or just run it?
Re: 360 LA-Magnum Head hy-brid oil pressure problem [Re: mjhallas] #375930
07/15/09 10:27 AM
07/15/09 10:27 AM
You're in perfect shape
Re: 360 LA-Magnum Head hy-brid oil pressure problem [Re: RapidRobert] #375931
07/15/09 10:36 AM
07/15/09 10:36 AM
Lexington Indiana
mjhallas Offline OP
mjhallas  Offline OP
Lexington Indiana
It just seems like a big varience range from cold to hot to idle.
Re: 360 LA-Magnum Head hy-brid oil pressure problem [Re: mjhallas] #375932
07/15/09 02:59 PM
07/15/09 02:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
once it hot...does the oil pressure go back up went the rpms go up?
if it does ..it is fine..
you basically need 10 psi for every 1000 rpm..
Tony
70 AARCuda Vitamin C
Re: 360 LA-Magnum Head hy-brid oil pressure problem [Re: 70AARcuda] #375933
07/15/09 09:55 PM
07/15/09 09:55 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Re: 360 LA-Magnum Head hy-brid oil pressure problem [Re: 70AARcuda] #375934
07/16/09 12:48 PM
07/16/09 12:48 PM
Lexington Indiana
mjhallas Offline OP
mjhallas  Offline OP
Lexington Indiana
Thank you, Guys, thought I had some work to do. This thing runs better than any (execpt for some hot 340's Ive had)small block I've ever had. Yet gets 12-13 mpg in the Power Wagon with 3.55's and 33's
