OEM Carter AVS tuning issue
#375674
07/14/09 10:41 PM
07/14/09 10:41 PM
Posts: 10,211 Someplace you aren't
SomeCarGuy
I found a new Eddy AVS for sale but decided to try a 71 440 AVS on my 383 first since it was on the shelf. It replaced the hated Eddy 750 AFB. I had the AFB running OK but I think the AVS will be better. I rebuilt the AVS I have this afternoon. It runs OK but is rich(more on that in a minute) and the real problem is that after it gets reved to about 3K, it idles about 1100 RPM. Curb idle holds about 750 where I want it, returns after blipping the throttle lightly. It only has one port for the vac advance so I ASSUME that it is ported. The AFB idled fine after a rev fest. Timing is 10/34. The engine is a stock 70 383 HP with a HSD intake and headers. Good chain. Thr rich issue at idle maybe caused by the idle screws not screwing in the same since I had to tap one that was stripped. I noticed they aren't the same but they are all I have at the moment. That shouldn't matter on the idle speed after reving. What might do something weird is the rods. I have a 630 AVS that I had to one from since this carb had a BENT rod. The 630 even had a mismatched set so I ended up with one 575 rod and one 572 rod. Could that be a factor in the hanging idle?
I want my fair share
Re: OEM Carter AVS tuning issue
[Re: SomeCarGuy]
#375679
07/14/09 11:32 PM
07/14/09 11:32 PM
RapidRobert
AVS strip kits are extremely rare nowadays & I think I just saw a parts AVS for cheap in one of the parts for sale sections which'd get you some rods. they might not be 100% correct but they would be matched but with that being said the AVS was an emission carb of that era of gov't regs that were starting to get severe(& the carb tech had not caught up and the AVS with its 3 step rods w the intermediate step are inferior to the earlier AFB(w 2 step rods)for performance so I would get an eddy strip kit & as you know the flat covers. I would take out the idle screws & straighten that out and anything else that's off especially w the rods getting bent by a prior owner
[Re: SomeCarGuy]
#375684
07/15/09 12:03 AM
07/15/09 12:03 AM
RapidRobert
Not sure but it is a controlled vac leak(which can raise the idle speed)(though a small one) but I think other issues going on especially with you being able to blip the throttle & it straightens out and did you say it was part time which(in this case) point to a mechanical hangup.
[Re: RapidRobert]
#375685
07/15/09 12:12 AM
07/15/09 12:12 AM
SomeCarGuy
It ran fine in the garage, so i took it down the road. Noticed the hangin idle and came home. Tried to pinpoint and figured out it was around 3K that it caused it not to idle right. A few blips and it clears.
[Re: SomeCarGuy]
#375686
07/15/09 12:18 AM
07/15/09 12:18 AM
SomeCarGuy
I went out to take the cable off and test and thought better about waking up the world. So I looked around for my AFB stip kit to see what rods and jets I still had. Getting discouraged, I made a discovery that is hard to believe. Hidden in a box on the top shelf was ANOTHER 71 440 AVS! Praise the lord! Not only is it the same 4966 carb, it appear to have never been touched- ever. It still has the blue carb tag on it, still had the factory air cleaner stud. Dirt and grime appear consistant all around. I sprayed the idle screws down and carefully worked them back and forth- move pretty well. They are dead even sticking through the bore. I pulled a rod and it is a 572 like the other carb. SO I guess tommorrow I will put the new accel pump in it and see what we get. One other note- the hot idle compensator is still in this one. I'll give it a whirl as is before I go and lead over anything.
[Re: SomeCarGuy]
#375687
07/15/09 08:56 AM
07/15/09 08:56 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
FYI the 4966 is a 650 carb , not a 750 , it's application is 71 non HP 440 and it will be RICH on your 383 since it is calibrated on the rich side for the 440 it came off of. The factory calibration was a compromise to save on warranty issues.
[Re: SomeCarGuy]
#375689
07/15/09 11:09 AM
07/15/09 11:09 AM
JohnRR
U.S.S.A.
That's right, I do remember looking that up awhile back.
I installed that same carb on a 330HP 383 and it did run very well for the few times I did drive the car .
[Re: SomeCarGuy]
#375691
07/15/09 09:36 PM
07/15/09 09:36 PM
SomeCarGuy
OK, after much fiddling today, I got the untouched carb on there and working. It had a few issues but i worked them out. Right now I have two problems with it. One is the idle seems erratic. I smoothed that out with adjusting the mixture but it still seems rough compared to the Eddy 750 AFB. Also, I feel a slight lean surge at part throttle. I saw a comment online while searching today that a drop base air cleaner will cause the carb to idle strange as it outs the lid too close to the idle bleeds. Might this be my issue? I could drive a little with it off and check I suppose. So far it has been less smooth than the Eddy was and that was why I wanted to change it out
